IGyro 3e in Delta - cant center the servos
Reply
Old 05-16-2017, 05:18 PM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default IGyro 3e in Delta - cant center the servos
Hello
I have a Tamjet/Feibao Rafale that I have been flying for a few years with excellent results. It uses elevon with one servo in each surface.
I now wanted to add an Igyro 3e. Realized needed to change the TX model to "normal" to allow the Igyro to do the mixing. No problem. All surfaces moving in the right direction after doing so.
My issue is that I cant center the elevons. The two channels going to the elevons are now either aileron or elevator signal. So any change in any of the signals will move both servos at the same time.
Evidently in my prior model (TX setup as Delta) I could center each servo individually in the radio, but cant do that anymore. I don't think the iGyro 3e has a way to adjust one servo only.
Is my only option to get the surfaces centered mechanically?
Edgar Perez is offline
Old 05-17-2017, 03:31 AM
joeflyer
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a similar issue with my Gripen. When I adjusted them mechanically the throws weren't right. After several notes back and forth with their tech support they determined that the gyro was defective and replaced it. Go to the Powerbox Tech Support website and see what they say.
joeflyer is online now
Contact Us Archive Advertising Cookie Policy
