JR Axis 3-axis gyro
ON, CANADA
Glad you got them cheap! I have two, flying one in just a 35CC AJ Laser it is working. Myself and another fellow have came across some major software issues on plane setup when centering and adjusting end points and rates of servos. I know Matty Matt a JR Rep had one in his jet. Personal I would use something else in my jet. All adjustments can be made from your transmitter. I am using a 28x.
CO
I have 6 of these and they work great. But you have to use xbus setup. On a turbine jet, you would want to use the high current servo adapters and hubs to power your servos. Can also be setup using PC software and a standard mini USB cable
