Blue Angels: New scheme with Super Hornets
I heard a rumor that the Blue Angels will have a new scheme with their upgrade to the Super Hornet. Anyone know if that's correct? If so, are there some concepts floating around?
Some Senators and Congressmen are getting palms greased for this one. The demo team aircraft are stripped down versions of the original aircraft to reduce the weight so they are much more maneuverable. Super Hornets will be too heavy and good pilots re going to get killed.
My Feedback: (57)
TBird F-16s are not stripped down at all. They merely remove the empty Ammo Drum, and replace with a smoke fluid tank + tubing. They keep everything else intact.
David
My Feedback: (9)
Not to mention they have had a few crashes and if I remember right their was issues with fatigue on something with the ailerons.
You can't fly planes forever. They must be replaced every now and then. Saying the super hornet can't hold up to what a c model does is crazy and miss informed.
My Feedback: (28)
I even worked on one that lost a fuel pump on the way to a show right before I left the Navy. They are not just stripped down versions. Other than pylons and armament everything was still there. There was very little difference between my Seagoing Hornets and theirs other than theirs were A models and ours were C models, and theirs were much dirtier inside, a lot of the fasteners were almost stripped, and the workmanship of the mechanics was shoddy at best.
This has been in the works for years so politicians getting greased is also a misnomer.
VFA-113 PowerPlants Aviation Machinists Mate.
My Feedback: (34)
The current F/A-18A & C models they're flying now are WELL past their standard service life. They had A LOT of reliability issues this year in winter training causing them to use spares on a daily basis. The older hornets simply can't fly forever. As with their current aircraft, the Super Hornets they'll get will be earlier block airplanes.. They're aren't 'stripped down' at all except to remove the gun, and replace it with a smoke tank, and adding a stiffer spring on the control stick to give them the down trim pressure they use for formation flying..
