T-3 Pics and Build
Old 03-04-2019, 09:12 AM
  #276
Digital Pilot
Digital Pilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Copy that, Just wondering what you went with.
Digital Pilot is online now
Old 03-04-2019, 05:45 PM
  #277
rcmigpilot
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Westwindpilot86 View Post
Jeff,
There a few different servos in the jet.
Flaps and ailerons have futaba 9157s.
Elevators are jr 8911s.
Rudder is a jr 8611a. And I believe that 8611 just has a bit to much slop. I am flying futaba.
But I will be moving my CG back to 350 for this weekend and put a different servo in the rudder.
I don't think slop is causing the jitters, I have the same issue with the 8711 on the rudder of my Sback. Some of the older, non programmable digital servos, like the 8611 and 8711 had very tight dead bands. Since there is no load on the rudder on the ground it messes with the servo (don't remember exactly what's going on). What I did, after reading a lot of posts on the issue, was glue the fuzzy side of a small strip of Velcro to the top of the fin. It just barely rubs on the bottom of the rudder counter balance, not enough to effect the rudder, but enough that the servo sees a tiny bit of load, twitching went away.
rcmigpilot is online now
Old 04-20-2019, 05:58 AM
  #278
rcflyguy_26
My Feedback: (8)
rcflyguy_26's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys,
Check your ball links... While going through my T3, I found the ball is loose inside the plastic on all the stock links. It's not alot, but I can spin the ball easily with some slop. I'm replacing all mine with the Dubro monster ball links and titanium rods.
Scott
rcflyguy_26 is offline
Old 04-20-2019, 08:52 AM
  #279
clavin
clavin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Digital Pilot View Post
Dial in about 1/4-1/2 Crow and you will love it!
Good luck, Post photos..
Kris,
1/4 to 1/2 INCH crow?
clavin is online now
Old 07-20-2019, 02:45 PM
  #280
sc0tt
My Feedback: (61)
sc0tt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can someone please give the T-3 fuel tank dimensions? measurements don't have to be exact, but close. Also, is the main tank a true 7.5L (256oz) ? I'm looking at this tank for a different jet project. Thanks...
sc0tt is offline
Old 10-01-2019, 11:22 AM
  #281
Digital Pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FYI All
Selling my T-3 Purple Monster BNF With a K260G2
You can find it in the Classified Section here on RCU!
Old 10-12-2019, 07:23 PM
  #282
Srobinson352
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Gear door
Originally Posted by jsnipes View Post
Work today focused on nose gear and door. Door will be servo actuated.
did you have issues setting the hinges for the nose gear door? Iím having an awful time setting the hinges.
Srobinson352 is offline
Old 10-13-2019, 07:25 AM
  #283
makis
makis's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
T-3 Manual is Complete..
Hi, guys, I received my T3 a couple of days ago and I intend to use MKS777+ servos on all surfaces. I have a question concerning the servo arms I can use. Although the manual states clearly that we have to use 1" arms, (except for steering), I have in my workshop 20-25 pieces aluminum arms (25T) 1.2" and 1,5" lengths available. What lengths did you use guys for your T3? Is there a problem to go with the sizes that I arleady own?
Thanks in advance,
Makis.
makis is offline
Old 10-13-2019, 08:52 AM
  #284
Srobinson352
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Nose door
Thats a bummer... This is the main reason why i fully boxed in my nose door area... I boxed in around the steering servo and gear as well...
Did you end up putting the door back on? Iím having a tough time setting my hinges. Any tricks to it?
Old 10-13-2019, 09:57 AM
  #285
Digital Pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
  #286
Digital Pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This worked incredibly well!
Old 10-13-2019, 10:26 AM
  #287
Srobinson352
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Gear door
I like it!! just a couple questions for details: 1) is the door strut actuated and if so what hinge did you use?
Old 10-13-2019, 12:35 PM
  #288
Digital Pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One single heavy duty Dubro large flat pin hinge in the center. Made a wood block shaped to the strut, position and glue onto door. I tape it when transport. The air keeps it closed during flight.
Old 10-13-2019, 12:49 PM
  #289
flyloose
flyloose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks in advance,
Makis.
I don’t have a T-3 but from a conceptual standpoint, going with larger arms than necessary will give you more throw at the EXPENSE of resolution....
A fellow modeller from my area has found that 22mm arms give the correct geometry on the T-3, FWIW
flyloose is offline
Old 10-13-2019, 06:50 PM
  #290
FlyJ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks in advance,
Makis.
You'll be ok everywhere except the flaps. The servos have little room between the servo door and the upper skin in the compartment.
FlyJ is offline
Old 10-13-2019, 07:06 PM
  #291
Westwindpilot86
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1 inch on flaps, ailerons, and elevators. 1.5 on rudder. Whatever you want on steering. All my throws are around 100 on all surfaces.
Westwindpilot86 is offline
Old 10-14-2019, 01:46 AM
  #292
makis
makis's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Smile
Thanks a lot for the info guys!! I'm sure I'll be back with more questions during the building process......
makis is offline
Old 11-02-2019, 11:25 AM
  #293
makis
makis's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys, I'm confused, please advice.... The little plys are options for aileron, elevator and rudder servos? Did you used them during building process? And the screws... I've got two sizes in the hardware pack, which size is the one to screw the servos?
Thanks in advance,
Makis.
makis is offline
Old 11-02-2019, 11:33 AM
  #294
Westwindpilot86
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Longer screws are to hold servos in. Shorter ones I believe are for the servo covers. I did not use the plywood pieces.
Old 11-02-2019, 01:28 PM
  #295
rcflyguy_26
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the plywood pieces to shim the servos up toward the hatches so more arm stuck out.
Old 11-03-2019, 12:14 AM
  #296
makis
makis's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the input guys, another question: Did you use some kind of wood glue on the screws before screwed them onto the wood? Just for safety?
makis is offline
Old 11-03-2019, 03:47 AM
  #297
rcflyguy_26
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a small dab of thick CA
Old 11-05-2019, 12:53 PM
  #298
Westwindpilot86
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used duco. Bought it off amazon. Itís just like ambroid. Holds the screw in but releases when trying to get a screw out. Great stuff.
Old 11-06-2019, 04:16 PM
  #299
Blinky
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If any bodies are in need of new never installed full set of retracts landing gear for T3 call me lines, tanks and gear. 773.507.8534
Blinky is offline
Old 11-11-2019, 08:14 AM
  #300
makis
makis's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys, did you use the fuel stock fittings for this jet? I intend to put a JetsMunt 200XBL and the fuel holes seems to be very small for me, in my opinion....
Any related info will be much appreciated.
Makis.
makis is offline
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
