Reload this Page >
New Sport Jet: T-One Models Mini Fortune / Mini T1
Reply
Old 12-03-2018, 05:15 PM
  #776
F1 Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by tucson View Post
i am running both rec batteries through a dsm 10 (jeti). I question if it will be alright to use one of those battery for gear and brakes.
We run aux devices (gear/brakes/lights etc) off one of the RX packs in many airplanes. Never been an issue.
Danny
F1 Rocket is online now
Old 12-03-2018, 05:56 PM
  #777
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Danny
Humm even the JP Retract?
I always do the same thing using the #2 battery, but in this case since we replacedwill replace the controller......it create another problem the voltage of a 2s is too high for the gear electric motor...at least that’s what we are told and I tend to believe it’s truth...
With the Xicoy LG15 Controller.....
Dansy is offline
Old 12-03-2018, 05:59 PM
  #778
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ďthe DSM10 doesnít regulated the voltage just a good switch for dual batteryís, I use the same on the mini.....I will try to check the voltage this week....been busy, as it stand I wouldnít do it without testing with a voltmeter
Dansy is offline
Old 12-03-2018, 06:21 PM
  #779
F1 Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I always do the same thing using the #2 battery, but in this case since we replacedwill replace the controller......it create another problem the voltage of a 2s is too high for the gear electric motor...at least thatís what we are told and I tend to believe itís truth...
Well..... not the JP gear that comes with the Mini T One so please heed the manufacturers advise. The JP gear on the Joker has been ok on 2s LiPo power.
Danny
Old 12-03-2018, 06:24 PM
  #780
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The JP brake tend to lockup’s and are far from proportional hence the reason I will try the Xicoy LG15 Gear/brakes controller.
Dansy is offline
Old 12-04-2018, 02:24 AM
  #781
gunradd
My Feedback: (9)
gunradd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The stock JP controller does have a regulator thatís why itís rated for 2cell Lipo. This is also why the cable connecting the JP to your receiver should have the power wire cut and only a signal wire for retracts. It could back feed 2 cell Lipo into your receiver. This might have been changed on later J P stuff.
Xicoy is is a pass through no regulator. Only use 2 cell LIFE and your good.
gunradd is online now
Old 12-04-2018, 03:29 AM
  #782
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The JP brake tend to lockupís and are far from proportional hence the reason I will try the Xicoy LG15 Gear/brakes controller.
i added just the Xicoy brake controller works great. No need to change the gear controller.
Bob_B is offline
Old 12-04-2018, 06:41 AM
  #783
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The output voltage on one of my JP controllers is 7.5 volts with a 2S Lipo on the input. The first mini I had with the LG15 ran the retracts fine with a 2S Lipo, no problems after 26 flights. The second mini I did the same setup and burned up a couple of retract motors until I figured out the 7.5v output of the JP controller. Iím running 2 x 2S LiPos for the receiver/servos, from one of these two batteries I run a line to the LG15 with a small 10 Amp CC regulator set to 7.5v. I do it this way because it donít want to add another battery. -Tom
Tip22v is online now
Old 12-04-2018, 07:42 AM
  #784
tucson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Xicoy brake controller
bob i also added just the xicoy brake controller.
while it did helpwith the locki ng up of the brakes it did not help with one brake being stronger than the other. So the problem i had of stopping in a straight line was still there.
this is why i elected to go with the lg-15. I M in the process of setting it up.
after watching Tom's video of his straight landing
and what he had to say iii am going to try the lg15.
tucson is online now
Old 12-04-2018, 08:12 AM
  #785
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had to do some playing around with the settings in the LG15 to get it dialed in, if there is interest I'm happy to post my configuration settings to give you a good place to start. - Tom
Old 12-04-2018, 08:55 AM
  #786
tucson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Lg-15
that would be great Tom. I just started making new leads, but to be honest i haven't gotten into it yet, and it does look confusing.
stan
Old 12-04-2018, 12:25 PM
  #787
camss69
My Feedback: (46)
camss69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For anyone interested, hereís the best pic I could get of those Fuel Hose Zip Ties I ordered earlier. This is 4mm fuel line on a barbed fitting, it looks pretty good to me no perceptible pinch point or gap that I can see and I zipped it down as tight as I could get it. These are the 4Ē zip ties and it looks like the 4mm line is about as small as you would want to go. The 6mm stuff is even better being slightly larger.
camss69 is offline
Old 12-05-2018, 06:52 PM
  #788
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
stan
It was nice talking with you today Stan. After our discussion today I realized that I could just save the config from the LG to a file and email it to you if you want. That way all you have to do is load the config file and you'll be in a good starting point. Let me know and I will send you my config file.
I created a new thread on the Jet forum for the setup of the LG15: Xicoy - LG15 Gyro Controlled Brakes
I figured we were deviating a little too much from the T-1 mini by going too deep into the settings of the LG15 here. Anyway, I posted some pics of my configuration is the Xicoy LG15 thread. I have not yet posted the portion for the gear door sequencing, I'll do that part tomorrow evening, it looks far more intimidating than it really is. -Tom
Old 12-15-2018, 10:46 PM
  #789
camss69
My Feedback: (46)
camss69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I pulled the magnets out of mine today and the brakes more linear and donít require 3/4 activation before they engage as before. Definitely a mod worth the time IMO.
camss69 is offline
Old 12-18-2018, 11:36 AM
  #790
T3chDad
T3chDad's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flight # mid-60s. Edited from one continuous flight shoot. Not my best landing, but took the points for the Fast and Furious drift. Not bad for this being the first time my friend used this camera. I hope you enjoy it.
T3chDad is offline
Old 12-20-2018, 04:41 AM
  #791
T3chDad
T3chDad's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unable to edit the post above (Seriously RCU!!??? ). So here's a new link.
T3chDad is offline
Old 12-21-2018, 01:11 PM
  #792
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice flying, thanks for posting -Tom
Old 12-29-2018, 12:19 PM
  #793
firehawkzach
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So my mini T-1 showed up today and wow it is beautiful! The customer service I have received from Dirk is unmatched in the RC business and I'm thrilled by the quality and price point of this jet.
I ordered mine with the PNP option so everything is installed. This is my first time looking at the JP electric retract controller and I'm trying to drop the gear so I can stand it on its legs. Can anyone give me the shortcut on getting the gear down? I have not installed the receiver yet as I still have a lot of work to do. Is there a way to put power on the controller and extend?
Zach
firehawkzach is offline
Old 12-29-2018, 01:18 PM
  #794
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can use a servo driver and a battery for the driver and the retracts
Bob_B is offline
Old 12-29-2018, 02:02 PM
  #795
firehawkzach
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So the brake controller uses 7.4v and the retract controller uses 7.4 or 6v? How did you guys run batteries and such?
Old 12-29-2018, 02:03 PM
  #796
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zach
you might want to disconnect the nose gear door servo before extending the gear to make sure you donít damage the gear door if everything is not sequenced correctly.
Old 12-29-2018, 02:15 PM
  #797
firehawkzach
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good call. The leads are combined for both controllers on an XT60 which I don't have. I either need to buy some XT60's or change over to deans since that is what most of my rc stuff is already.
Old 12-29-2018, 02:18 PM
  #798
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I power my brakes/retracts directly off one of my two receiver batteries. Note, Iím not using the OEM brake/retract controller, Iím running a Xicoy brake/retract controller but you should still be able to power the oem controllers directly from one of your receiver batteries.
Old 12-29-2018, 02:25 PM
  #799
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are using Deans on everything else you can swap out the connector. I switched over from Deans to XT60 on everything about 6 years ago, just found the XT60 connectors easier to solder. If you donít want to cut the connectors on your new JP controllers you can also make or buy a converter.
Old 12-29-2018, 02:36 PM
  #800
camss69
My Feedback: (46)
camss69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zach
Iíd love to see the the install pics.
camss69 is offline
