Reload this Page >
New Sport Jet: T-One Models Mini Fortune / Mini T1
Old 04-24-2019, 03:57 AM
  #1026
Digital Pilot
Digital Pilot's Avatar
Originally Posted by dribar
Messy, but getting closer.... Going to balance again tonight and then lock things down.
Q: Is it ok to put the fuel filter in the second bay, closer to the turbine?
Safety Wire all your connections......
Old 04-26-2019, 02:07 AM
  #1027
dribar
Do you Spektrum guys have a recommendation for routing / placement of my main antenna wires? I have the three remote receivers that will be on diverse planes, but not too sure what to do with the two main wires. I sent an email into horizon for guidance, but no reply yet.
Thanks.
Old 04-26-2019, 08:24 AM
  #1028
camss69
My Feedback: (46)
camss69's Avatar
I would put them along either side of the fuse as high up as you can get them. You’re pretty limited where you can go with those. It’s going to look at which ever satellite or main antennas have the best signal. The satellites are full receivers as well so as long as you have at least one with a good signal for every orientation of the plane (as best you can) you’re good to go.
Old 04-26-2019, 11:35 AM
  #1029
why-me
They should be 90° to each other. I used this setup in my T1
Old 04-26-2019, 01:02 PM
  #1030
dribar
Yeah... someday... when I go to heaven, I'll have a jet that looks like that
Old 04-26-2019, 01:35 PM
  #1031
Dansy
My Feedback: (53)
Dansy's Avatar
Isn’t that 180 degrees ?
Old 04-26-2019, 02:37 PM
  #1032
camss69
My Feedback: (46)
camss69's Avatar
i was thinking the same
Old 04-26-2019, 03:32 PM
  #1033
why-me
​​​it's just the way the pic looks. It is a antenna holder kit from hobby king. The straws that hold the antennas are at 45°so they hold them at 90°.
Old 04-28-2019, 04:58 AM
  #1034
dribar
OK -- you guys didn't tell me safety wire is sharp... causes punctures... and thumbs like to bleed
Note: I left the output of the pump loose so I can prime back into the fuel can. After the prime, I'll connect the tube to the turbine and safety wire it.
And yes, those are universal bonding strips on the walls.
Old 04-28-2019, 05:22 AM
  #1035
Tip22v
In the future make sure you double wrap the safety wire before twisting it, that way you eliminate any chance of crimping the fuel line, which could introduce air in the line. -Tom
Old 04-28-2019, 05:35 AM
  #1036
Dansy
My Feedback: (53)
Dansy's Avatar
When I prime the line I always prime all the way to the motor, that way you don’t get the flame while it try to start.....
Old 04-28-2019, 06:44 AM
  #1037
gunradd
My Feedback: (9)
gunradd's Avatar
Hate to say it but you need to cut all tat safety wire off and redo it. Needs a double wrap or it can pinch and leak. I would not trust it like the others said.
Old 04-28-2019, 08:08 AM
  #1038
dribar
Ok - no worries guys. I appreciate your knowledge.
Old 04-28-2019, 08:39 AM
  #1039
dribar
OK -- check this out. I wrapped around twice then twisted. Right?
Old 04-28-2019, 08:44 AM
  #1040
dribar
OK -- will do.
Old 04-28-2019, 09:23 AM
  #1041
Desertlakesflying
My Feedback: (28)
ok -- check this out. I wrapped around twice then twisted. Right?
Much better! Although your twists don't look right. Looks like one side wrapped around the other instead of the wires wrapped around each other.
Old 04-28-2019, 10:32 AM
  #1042
camss69
My Feedback: (46)
camss69's Avatar
i think that’s just the light in the pic or whatever, they look ok to me. But I used the fuel hose zip ties on mine..
Old 04-28-2019, 03:42 PM
  #1043
dribar
OK -- once more with feeling. I made sure there is a continuous loop of wire around the tube by double looping it.
Old 04-30-2019, 03:30 AM
  #1044
T3chDad
T3chDad's Avatar
Due to 150 abusive flights and a too many run-out-of-airspeed-landing-plops on the landing gear, I had very small cracks developing on the top of the wing directly above the landing gear. I have them fixed and reinforced from the inside, but I had to cut out the landing gear wells (picture).
Any suggestions on a good way to close this in again?
Old 04-30-2019, 03:04 PM
  #1045
T3chDad
T3chDad's Avatar
I figured it out. I glassed below the hole on the inside top surface of the wing and then stuck two layers of 6mm Depron foam cut to shape. Then I glassed over that and covered it with black vinyl. Ready to fly!
Old 05-01-2019, 01:42 AM
  #1046
dribar
Quite ingenious and industrious. Nice job.
Old 05-01-2019, 01:47 AM
  #1047
dribar
My wife and I did the fuel system prime, and then decided to start her up last night. Only had one neighbor text and suggest we were being too loud... so I'd call it a success. I also put her (not my wife or neighbor) on the balance stand again and she was at195 -- which I'm happy with as a starting point for the first few flights.
My last thing to do is re-check all of my surface deflections. I use both rates and expo, so I set them all to the manual settings while on mid-rates.
Maiden could happen this weekend if the weather and other pilots line up.
Old 05-01-2019, 03:41 AM
  #1048
sirrom
Default Mini t1
Congratulations Dan..on the first start and only 1 neighbor complaining...LOL.
Patrick
Old 05-01-2019, 03:43 AM
  #1049
T3chDad
T3chDad's Avatar
I saw your video on FB. Good job. I always forget the valve too.
It's a shame you can't make some noise for, what 3 min in the middle of the day, without someone complaining. I grew up in Tampa and lived in Clearwater for my last five years in FL. I don't miss the Old Fart Factor® I wish you good luck and success whenever you maiden her (not your wife, the plane). Name:  rofl.gif
Old 05-01-2019, 05:11 AM
  #1050
sirrom
It's a shame you can't make some noise for, what 3 min in the middle of the day, without someone complaining. I grew up in Tampa and lived in Clearwater for my last five years in FL. I don't miss the Old Fart Factor® I wish you good luck and success whenever you maiden her (not your wife, the plane). Attachment 2264094
Fortunately it's not all neighborhoods in Fl. I can start my motors (Turbines and 100cc) without anyone complaining. Most times the neighborhood kids are making noise so most on my cul-de-sac are used to 'noise' in the neighborhood. Plus I think my plane runs are more welcomed noises than my neighbors 8 year old girls screams. You think a turbine is high pitched, you should hear this kid..LOL.
Patrick
