CARF Joker build thread
#602
My Feedback: (17)
Hello,
Finally got to the fuel system build in.
Any suggestions for the UAT? I can’t see how the supplied UAT can be build in.
Noticed there was no clunck supplied with. Where should i put this tank?
Did somebody used the itrap UAT?
Pls provide pics if possible.
Kind Regards,
Eric
Kind Regards,
Eric
#604
[QUOTE=Saillfish;12507746]I went with the Hanson UAT It's exactly like the BVM one. Just 25 dollars cheaper. Always worked perfect for me.
Hi Sailfish,
Many thanks for your feedback and pictures.
Looks like you also used a non standard UAT, rather then the supplied one...
Regards,
Eric
Hi Sailfish,
Regards,
Eric
#605
#607
My Feedback: (17)
Manual says 8mm up crow at the root. That would be measured at the flap right? It doesn't seem like much crow. But if you do 8mm up at the outboard side of the aileron it makes it about 15 mm up at the flap. So which is correct Also, what has everyone found to be the best throws? And what does everyone's weigh in at? Mine comes in at 17lbs 9 Oz with all batteries and UAT full. That's quite a bit more than the 14 lbs it claims. Thanks!
#608
I don’t use any CROW, with the JetCat low idle thrust it’s not needed, but you should not use much as it removes so much lift.
measured at the root is how it’s meant.
#612
Hi Guys, I’m proud to say Iv brought a second hand Joker with a Wren 70 :-) :-) it will be interesting to see what the Wren 70 is like on our grass field but first flights will be taken off at RAF Coningsby so no worries about runways lengths to start with. My question is i’v only got a DX9 so i will have to Y lead at least one set of controls, what would people say is the least risky option? I would prefer the elevators to stay separated just for redundancy. Would flaps be ok on a Y lead? I didn’t have this issue with my Xcalibur.
Thanks Tom.
Thanks Tom.
#613
Thanks Tom.
Thanks Tom.
#616
Thanks Dave, I think you know Jamie who I brought it off?
I’m not so nervous of flying it as just coming in on the landing circuit with the flaps down. The Xcalibur is so easy to fly/land hopefully this won’t be too much harder. I’l order one of the above thanks.
#617
Yes, guessed it was Jamie’s model. If you coped with the Xcalibur you have nothing to worry about. Just remember the down elevator needed with flap
Dave
Dave
#619
My Feedback: (17)
Joker madian today
Flew the joker for the first time today. CG at 180mm. Weight is 17.6 lbs with all batteries less fuel. All throws as per thread and it flew beautiful
Watch "Comp Arf Joker madian flight" on YouTube
https://youtu.be/ZdJYSAwkBxA
#625
Dave W, from Motors & Rotors flew his CARF Joker at the first JMA Meeting of the season over the weekend at the BMFA National Flying Centre, Buckminster Lodge.
This one is a Jetcat P-100 powered, with the PowerBox Core Radio System, the weather on the day was good, however the stiff breese did cause some local turbulance over the boundary approaches The Joker looked totally locked in, and very stable.
The landing gear on this Joker has probably seen more grass (sod) than hard runways, and has been totally reliable.
