Pilot-rc PREDATOR 2.2m Sport jet / full composite
#576
My Feedback: (50)
I just sold my Elan to a flying buddy. Looking for my next jet and I'm thinking this is it. I read through the entire thread last night and it appears the only negatives are the issue with the finish, which isn't a deal breaker at all. Oh, I forgot about the bent wing tube, has this been resolved by Pilot RC in the latest shipments? Anyone have concerns about the landing gear operations?? Thanks!
#577
My Feedback: (75)
TX
I’m on my second Predator. On both, finish has been good......no issues. On my first one, I never bent a wing tube from flight. I had a bad landing and bent the tube. I straightened the tube when I made the repairs. No more issues. The first one is now deceased. I am keeping the old wing tube as a spare. I now also have a cf wing tube, but it is not as tight fit as the aluminum tube. Current wing tubes are fine for my flying.
#578
This a great jet to transition from an Elan. In some ways it’s probably easier to fly then the Elan! As far as the finish goes, I have mentioned it in a past post. For the price I feel that the finish is very good, and it’s sport jet, not a competition scale model. Mine has a few hundred flights on it now and it’s holding up very good, most of the “dings” are hangar rash and not from flying. The build quality and finish in that regard is very good, I’d say up their with some higher priced brands. So it’s got it where it counts if you ask me. As for flying, it flies very good, with little to no bad habits. I got it “snap” but really had to aggravate it to bite, and even then it was pretty easy to recover. The gear for me has been flawless, works every time and the brakes work good as well. I’ve has a few less then perfect landings and the gear/airframe show no signs of ware or any breakage as a result of the hard landings. I especially like that you can extend/retract the gear without having to turn on the plane or your TX. Great for setting up and taking apart at the end of the day.
#579
My Feedback: (23)
NY
I love mine. I transitioned from a sprint. Was easy to fly right from the start. The more I fly it the better I like it. My only comment is on engine size. Don’t be afraid to go big. I started with a 140. Then tried a 160 and now I have a 210. The 210 is awesome.
#580
My Feedback: (50)
Thanks for the feedback. Great information. Love to hear the factory supplied gear are holding up to everyday use. There are too many stories about gear that’s supplied with a plane just not doing well.
#581
My Feedback: (23)
NY
The gear is really strong.
#582
The landing gear works great. The other day when I got back from flying I forgot to remove the battery from the retract controller. Well I soon learn that the system will deploy the retracts by it self if the batt voltage drops to low. My nose gear didn’t come out all the way and I was expecting for the nose retract motor to be burned out because the jet was laying on top of a moving blanket on the floor witch obstructed the nose retract but to my luck everything works as advertised. The system must have some sort of protection against binding. The only Issue I have for some reason is settling the brakes. I get full brakes or nothing. Can’t find the in between brakes. Lol
#583
My Feedback: (50)
Great feedback and good to hear the gear system is robust - thanks
#584
My Feedback: (23)
NY
My breaks are the same. On or off
#585
My Feedback: (53)
That’s how it actually stop the down and up actuation since there’s no micro switch to wear out or damage with time....
#586
AZ
as for the brakes, yeah, they're not the best. But a little fine tuning and some silicone spray on the drums to help wear them in can help also.
#587
AZ
So, after a few flights on this jet, I have decided I'm just not happy with the wing clamp method. Every time I taxi back there is more gap in the wing than when it took off. Not sure when in the flight it is happening. Don't care. Don't like it.
I ended up installing a threaded insert in the wing where they had already drilled a relief hole for the CG screw since it is backed by a piece of plywood, and then I enlarged the cg
screw hole in the fuse to accept the 10-32 screw. It's a little tricky getting the screw tightened up, but it's doable, and worth it. This almost completely got rid of the gap that seems to be common with this aircraft, also.
of course, I will continue to use the clamp. This is just a confidence booster.
Rare earth magnet on the wrench stem keeps the bolt on while you maneuver it under the motor mount plates.
#588
WI
Hello. I am in the market for a nice 2.2 Predator ( latest version). Anything out there? I’m located in Milwaukee Wisconsin and willing to road trip it ( within reason!). TIA
PM or Rbtgold@aol.com
Robert
Robert
#589
WI
Hello Gang. I am interested in purchasing a new 2.2 Predator (via PilotRC usa) and would like to hear some flight reports/ quality/ set up. (I've heard a few instances about possible tip stalling which has spooked me !!!??). I'd appreciate any input.
Thank you
Robert in Milwaukee
Thank you
Robert in Milwaukee
#590
My Feedback: (19)
I enjoy mine. I have a k210 and thrust vectoring. It is a good change of pace from my Ultra Flash. It will fly somewhat fast but not a speed demon. Tracks well and a good aerobatic sport jet. I did not have any quality issues with mine. Of course it will tip stall. I don't have a jet that won't if you get it too slow or yank on it hard when going slow. It has tip stalled in the air messing around but I have never had a tip stall and thought, "dang, didn't see that coming." As soon as the elevator is released it gets back to flying nearly immediately.
#591
Thank you
Robert in Milwaukee
Thank you
Robert in Milwaukee
#592
My Feedback: (23)
NY
are you using the factory thrust vector or an aftermarket. I tried to get the thrust vector pipe from pilot and they wouldn’t sell it to me, said it has to come with the airframe.
#593
My Feedback: (19)
Factory. Reality is that it needs more air to breath. The 210 has more that 1:1 thrust to weight but even at full throttle backs down pretty fast. I think at low/0 airspeed and full throttle it doesn't get enough air. I have been thinking about how to add more air. Holes in the bottom would work but I fly off grass sometimes and think it would suck up a bunch of dirt. I already get grass in the fuselage.
#594
My Feedback: (19)
#595
My Feedback: (23)
NY
I have the 210 in mine and I think it is a great match. I also agree that it needs more air. I was thinking about vents in the bottom with a screen to keep some of the junk out.
#596
My Feedback: (23)
NY
#597
You're right...I couldn't enjoy this airframe with anything less than 180 size turbine. I also notice it would climb on full power...no need for gyro....On or off I can't tell the difference.
#598
My Feedback: (19)
This is all I have really. I bought the plug and play version so the servos were already installed.
I don't have any video of the plane really. I will say that it does pinwheel and flatspin like a beast with the TV.
#599
https://www.youtube.com/watch?v=lF5qS6ovXr8
https://youtu.be/407CP_imO9s
#600
My Feedback: (19)
