HSD blower for cooling down turbine
Reply
Old 10-02-2017, 05:31 PM
ltc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default HSD blower for cooling down turbine
I stumbled across this while searching eBay (couldn't sleep).
Looked interesting, so I bought it.
Heat Dissipation Radiator Fire Extinguisher For HSD Turbine RC Planes Model
Arrived promptly and safely from Hong Kong. The box and packaging was impressive...I wish planes were packed as nicely as this was.
It's a big piece of EPO foam with an EDF, ESC, variable speed trigger and a battery compartment with Deans (T) connector
Very light, lots of airflow (I tried it on a 4s, only really need a 3s to cool down a turbine)
Its nice since it uses any available RC LiPo. No need to bring another charger or battery type.
Here is the link to the HSD website
HEAT RADIATING AND EXTINGUISHING HAIR DRYER-Parts-HSDJETS
(No, I have no idea where they came up with the name ...Heat Dissipation Radiator Fire Extinguisher)
ltc is offline
Old 10-02-2017, 08:31 PM
Wclays
My Feedback: (85)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry
I do not see how this is any better than my Makita Blower?
I believe the Makita is probably built better.
Just my thoughts.
Wclays is offline
Old 10-02-2017, 09:19 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Wclays View Post
Sorry
Just my thoughts.
I keep looking at my local Home Depot and cannot find that little beastie either in stock or on the website. Have you got a model number for that Makita?
Thanks.
Zeeb is offline
Old 10-02-2017, 09:54 PM
Doug Cronkhite
My Feedback: (34)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A couple of computer fans attached to a lipo sitting in the intakes with a foam seal around them would work just as well if you have a full inlet/bypass system. Just something to move the air through..
Doug Cronkhite is offline
Old 10-03-2017, 01:41 AM
ltc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks.
Makita 179-MPH 91-CFM 18-Volt LXT Lithium-Ion Cordless Blower (Tool-Only)-DUB182Z - The Home Depot
https://www.amazon.com/Makita-DUB182.../dp/B00NLXXQXQ
ltc is offline
Old 10-03-2017, 01:46 AM
ltc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry
Just my thoughts.
Not any better, just a new item I thought was different and worth posting
I believe the Makita uses a brushed dc motor which should have a shorter life than a brushless motor (if that is a consideration)
ltc is offline
Old 10-03-2017, 04:45 AM
ChuckC
My Feedback: (24)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the cordless/electric blower I got recently for $99:
https://www.directtoolsoutlet.com/ca...0947-115393325
58 volts, brushless motor, echo quality, etc. ...unfortunately it's a beast. To be fair, I got it for what it's made for, but found the lovely benefit of being able to actually blow out my garage - it's never stayed so clean (just don't hit the work bench full-force). It also has PLENTY of "oomph" to put out an internal fire, but I'd imagine way too big for anyone to lug around.
The Makita is still ABOUT the best option going so far, but Rigid makes a neat "job site blower" as well. About same price.:
RIDGID Gen5X 18-Volt Jobsite Blower Kit-R860430SB - The Home Depot
So - size/price and batteries I've already got - will be getting the little Rigid. You aren't going to wear out the brushed motor and charging one of the more recent blowers SHOULD last you most of the day.
ChuckC is offline
Old 10-03-2017, 09:33 AM
jetflyr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been using the Ryobi One+ blower for years.
I blew up the original (GASP!) blowing leaves out of the gutters, and just purchased a new one for $59.00
On all of these things, I throw their cheap battery and retrofit with an inexpensive ZIPPY LiPo, with balance taps out the side of the battery case. Have yet to ruin a battery this way :-)
Greg
jetflyr is offline
Old 10-03-2017, 10:22 AM
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been using this one
Ryobi 18-Volt ONE+ Compact Blower-P755 - The Home Depot
I got it and the battery for under $100 with a recent sale. It works good.
AEROSHELDON is offline
Old 10-03-2017, 12:58 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I think it's going to be the Ryobi as the local Home Depot has them in stock and I already have a cordless Ryobi hedge trimmer which uses the same batteries.
The Makita is no where to be found in local stores, which explains why I could never find one I guess..... lol
Zeeb is offline
Old 10-03-2017, 03:18 PM
ChuckC
My Feedback: (24)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That ryobi looks perfect. Nice and small. Cheap too. Good find.
ChuckC is offline
Old 10-03-2017, 03:31 PM
AEROSHELDON
My Feedback: (99)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Smile
Thanks!
The one the OP put up is great as well, just sharing what I use....
Old 10-03-2017, 05:29 PM
gooseF22
gooseF22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whichever one you use, you need blower wind speed if you use it for putting out a fire..
The blower is by far the most effective fire fighting tool available.. It will put out a tail pipe fire right now with no damage.. it will put out an exploded motor with fuel burning inside the jet.. It happened to me.. I had the fire out in 10 seconds. I put a brush fire out with mine once. a few crashes too.
My fireman buddy says its like opening your mouth at 90 mph in the wind.. it stuffs the fire.
I cannot recommend having a blower enough for jet flyers.. cheap insurance.
gooseF22 is offline
Contact Us Archive Advertising Cookie Policy
