Mini T1 Build
My Feedback: (53)
With the KingTech G2 you have/getting your better with the KingTech Telemetry.....works with Jeti and it will give fuel level
If it’s not the G2 then you have the choice between Xicoy which has fuel level if you have a Xicoy ECU, but you also need the programmer to adjust the fuel level.......or the TTU from Digitech.....
OR the m-flow which would be my preference......with the Xicoy....
Sweet I have G2 I wonder what data it shows on Jeti
Hi Guys,
After the 1st few Mini T-1's delivered and we heard about the difficulty of installing the door and servo, I talked to the factory about installing the door & servo at the factory while they are building the MINI. We pay the factory extra to install the Door & a HV servo to make it a easier and faster install for everyone, well Pacific's customers anyway. Plug the door servo into the controller and the controller will do the rest. You need the wings plugged in as well for everything to work. You also need to plug in a 2S battery into the controller unit for the brakes to work properly.
Enjoy the build and the Mini when you go fly!!
Dirk
www.pacificrcjets.com
Dirk
Hi Guys,
Dirk
Dirk
cheers
My Feedback: (10)
The dust does not worry me, just rinse it out with something. The thing you need to be 100% sure of is that you have no big blobs of glue inside that could break loose, or strips of glass, etc. These can break free and clog the pickup. I have seen this on more than one chinese arf tank.
#31
#32
Did you notice the tubing in the wings for the servo wires routing? We also had the factory incorporate that feature to make the install even easier. Looking forward to seeing it fly and getting my IN N OUT Burger & fries, you did say fries, right?? LOL
Dirk
