New F-18 Project
Reply
Old 10-12-2017, 06:28 AM
Shaun Evans
Shaun Evans's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default New F-18 Project
Hi
About to start yet another Y/A F-18 Twin build for twin 140's. Alongside a BIG BIG project from Ultimate Jets (TBA)....
Anyway, what are the 'in' digital servos these days? I'm a little irritated with my JR since I now have 4 8611's that have sat for a few years but are seized, NIB. What's everyone using these days?
Shaun Evans is offline
Old 10-12-2017, 07:30 AM
myersflyers
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MKS,some of the best around today. MKS Servos USA
myersflyers is offline
Old 10-12-2017, 07:46 AM
F1 Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can't go wrong with MKS. Their HV777A+ is IMO the best bang for buck around.
F1 Rocket is offline
Old 10-13-2017, 03:24 AM
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks! Any others to look at? Anyone else had their 8611's seize up while sitting NIB?
Old 10-13-2017, 06:04 AM
Doug Cronkhite
My Feedback: (34)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Adding my support for MKS. I've been running them for awhile now.. Can't say enough good things about them.
Doug Cronkhite is offline
Old 10-13-2017, 04:53 PM
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Doug,
Coming from you, that's a great endorsement.
Old 10-15-2017, 02:17 AM
bjm007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Shaun,
Try the New JR NX8931 Servo.
Direct replacement for the 8911/8711
They also have soft start,
Bruce
bjm007 is offline
Old 10-15-2017, 04:04 AM
Doug Cronkhite
My Feedback: (34)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The MKS HV777+ is a great choice.. 562 oz/" on 8.2v with a 0.1 sec/60 degree transit. Aluminum upper casing. $120 each
The next step up is the HBL380.. 570 oz/" on 8.2v with a 0.08/60 degree transit. Brushless motor, full aluminum case, at $190 each.
I'm putting the 380s in my new 40% aerobatic airplane, but the 777+ are more than enough for most applications..
Old 10-15-2017, 04:44 AM
Ceeray
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shaun, do you happen to know that from where I could get a 1/8 center line dt for F-18C as you seem to build them all year round?
Ceeray is offline
Old 10-24-2017, 11:55 AM
Airforce7
My Feedback: (31)
Airforce7's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Thrust tubes
Originally Posted by Shaun Evans View Post
Hi
Hi Shaun,
Which brand pipes are you going to use for your new project? In mine, I have a pair of Tam pipes rated for P-120s. In your experience, is it nessessary to fully enclose the turbines with a carbon fiber bypass?
Airforce7 is offline
Old 10-24-2017, 11:47 PM
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
We're planning to install Jet Tech pipes. As for bypasses, I'm not sure yet. AMA still requires a 'partition' for twins because of possible 'cross ignition' but I think that's an arcane concern with kero-start engines. I'm not sure what the up-to-date scratch is on that but we'll see. One thing I have experienced with this particular bird is that at high speeds, there's enough positive pressure inside the fuse to push two of the main gear doors open without a bypass on twins.
Old 10-25-2017, 01:13 PM
rhklenke
My Feedback: (24)
rhklenke's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Shaun,
That "partitioning" is no longer *required*. The safety code states:
It is recommended that multiple engines equipped with propane start be segregated or partitioned to prevent cross-ignition of exhaust gases.
So its not a requirement, just a recommendation, and its not applicable to kero-start engines.
Bob
rhklenke is offline
Old 10-25-2017, 03:04 PM
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Thanks, Bob! Shows how much I keep up with current AMA regs....
Contact Us Archive Advertising Cookie Policy
