K45 turpoprop
K45 turpoprop
Well now that Kingtech have brought our there K-45 turboprop I wonder if Skymaster will bring out a smaller version of the PC-21. I think this would be perfect for this engine. You could have a plane that’s easily handled by one person, and fits nicely in the trailer.
Anyone else thinks this would be good or am I just hopefull.
Thank you. I knew about the ESM. I know someone who is fitting a turbo prop to a ESM PC-21. However I was more hoping wondering if Skymaster will bring a smaller version out.
My Feedback: (10)
1 51216 16D 5-Blatt-Einstellnabe-16D - 12.0 Millimeter 75.00
1 99999 16D Distanzbuchse Aluminium - Da= 12mm, Di= 10 und 8mm 7.50
1 S5104-16 16D Alu-Leichtspinner-16D, PC21 11000 Gewinde M4 118.00
10 462-16 16D CFK-Rotorblatt – D - 7800 18.2" 462mm 68.00
2 16800 16D Kragenspinner-16D - Innengew. M8-M4 15.00
i ordered 10 blades just in case ;-)
you set the pitch to 20-20,5 inch , comes with a little tool.
i used to fly the kingtech with the 3blade 22x12 (stock)
you WILL have : more torque , more end speed(plane not revs) cooler temps on the turbine (60 degrees difference)
and very quiet!
so its worth the investment , and the scale look
yes it is expensive at first look , but the blades are cheap!
and the CNC work is one of the best i ever have seen , the spinner is the cherry on the cake.
Dont,s : DO NOT use this prop if you dont have a slim nose , this prop is designed to work from the root of the blade.
so if you have a Engine cover thatis bigger then the spinner it wont work to good.
all in all perfect for anything that is designed around a scale TP model
and yes Ramoser is very german ! so dont expect the perfect answer in english.
just do the order online with those part numbers , you will get after a few days a answer with the invoice.
tell him its for a kingtech K-45 turboprop .
he also has NO online payment system
