Dreamworks Electric Pro-Link retracts
My Feedback: (30)
I am debating on going with the air or electric retracts for my boomerang xl. I have air Pro-Links in my Sprint and they work flawlessly. Just didn't know if anyone had experience with the electrics and how they handle grass use since there is a wire going down to the brakes as opposed to an air line. Just looking for pros and cons.
Jason
Jason
My Feedback: (30)
I guess my main concern was how the lead connected to the brakes and if it stayed connected when flying from grass. I like the idea of eliminating airlines, pressure gauges, fill valves, etc..
Jason
Jason
i purchased a used Nano Bomer with Prolinks and added the Xicoy electric brakes. I Have over 80 flights on them primary on grass. Prolinks struts have held up well. Minor issues with pivot pin coming loose on struts. The electric brakes are OK but will start to drag when grass is damp or wet and then require cleaning. No problems with electric plug. Just wire tied to strut. I also have XCalibur with original struts and air brake set up. These have held up well on grass also. About 50 flights with 40 on grass. The air brakes on it thus far have not required hardly any maintenance as the electric has on the Nano. Both have air actuators. I would probably go with air brakes and JetTronics low loss brake valve on next plane if I have room for air tank.
On grass, you need smooth proportional braking to keep from skidding. Grass is almost as bad as a fiber mat for skidding.
I have Prolinks air in the Sprint and electrics in the Ultraflash. I initially got the Basic version of the electrics and found that the braking was totally unsuitable. Proportional Braking was not possible. Upgraded to the Pro version controller and the electrics are now tolerable. Comparing the two, the Air system works better for proportional braking if you use the right valve. The Jury is still out on the electrics. I had a hexx of time, to put it mildly, getting the electrics to brake evenly (w/o throwing the jet sideways). Next jet will be with air. That being said, I have tried several air brake valves. The only one that really works well is the UP 6 and believe me, I tried them all. Folks that are not using the UP6 don't know what they are missing. Given the 4 ranges of braking, it seems to provide very smooth proportional braking. Can't go wrong with air and a UP6.
