swinwin140
What version ecu? Brushless pump? If it's the latest version ECU I recommend updating all the firmware or at least verifying that it's updated. Acceleration/ deceleration settings are much easier in newer releases. How fast you want to accelerate is dependent on where you live in terms of elevation/ temp, and the airframe ducting. 3.5 seconds is very reliable, and I don't recommend going below 2.5 seconds except to show off acceleration times on the ground to your friends or you risk flame out.
pump voltage is dependent on type of pump and is different for every pump/ turbine.
