Introducing the TopRC Model Hawker Hunter - New Scale Jet
My Feedback: (51)
Hello guys,
I have acquired the first TopRC Model Hawker Hunter Scale jet to arrive in Israel by Sky Toys.
Top RC model is a very well known company in the scale RC prop planes field, that started producing jets a few years ago.
i have made build threads for their Odyssey, Aspire and currently the G4 Super Galeb right here on RCU.
TopRC Odyssey build thread:
http://www.rcuniverse.com/forum/rc-j...ld-thread.html
TopRC Aspire build thread:
TopRC G4 Super Galebbuild thread:
http://www.rcuniverse.com/forum/rc-j...html?styleid=7
once i saw this jet at Jetpower 2017 in Germany, i was hooked! it is simply gorgeous and the price was hard to beat!
The quality seems up there with the best of them and so is the finish, everything seems very lightweight!
Jet comes in a gorgeous matte finish swiss scheme modelled after tail number J-4021 pictured.
so, i will make a build thread about this exciting new jet and will keep you guys updated with anything i find while im at it.
The jet's specs:
Length: 2423mm/95.4in
Wing Span: 1770mm/69.7in
Flying Weight: ~16.9kg
Turbine: 12-16kg
Radio: Min. 9 Servos
required C.G: 240mm from the leading edge of wing root.
Description:
1. Full composite construction.
2. All surface prepainted,decals applied and clear coated
3. Scale cockpit included.
4. Detachable main wing and tailplane for easy transportation;
5. Removable hatch on fuselage for easy access into the fuselage.
6. Functional flaps.
7. High quality CNC Alu push rod included - with Heavy Duty hardware
8. More than 95% assembled complete in factory.
9. Tail tube and fuel tanks (2) included in kit
10. SCALE fully electric landing gear
11. Gear doors pre hinged and preinstalled.
12. Electric landing gear with electric brakes.
i am going to be using the following gear on the jet:-
ATJ 140 SV turbine (LOVE this engine!)-
Blue Bird BLS-3507 brushless metal gear high torque servos-
Emcotec DPSI RV Mini 5 power system with redundant lipo batteries-
Cortex Pro gyro-
Futaba 18MZ for control
Some pics as it is "Out of the box".
Check out the crazy packaging - best in the business !
Thanks to Sky Toys RC for making this exciting kit available locally.
The jet's specs:
Turbine: 12-16kg
Description:
Cortex Pro gyro-
My Feedback: (71)
404-263-7674
[email protected]
