Reload this Page >
Help with pneumatic electronic valves
Reply
Old 02-12-2018, 09:41 AM
c_makhija
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help with pneumatic electronic valves
Hi Guys,
Been flying my Skygate Hawk over the last 2 years, got around 25 flights on it so far.
Today had 4 flights on it. On 3 flights out of the 4 the gear did not retract. The gear so far has been working flawless with around 125 PSI of pressure.
No leaks in the up or down positions. And all 3 individual gears operate smoothly when directly connected to the air pump.
Only thing that comes to mind is a sticky valve. Is it possible these valves open partially which is not allowing enough volume of air to go to the cylinders, or could there be any other reason.
Changing the valve would be least of my worries.
Chatty.
c_makhija is offline
Old 02-12-2018, 09:48 AM
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did it partly retract? Were you taking off faster than normal, leaving it longer to retract the gear?
Speed is a big issue with the Hawk. Did the nose go?
Dave Wilshere is online now
Old 02-12-2018, 11:02 AM
c_makhija
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes Dave, it did partly retract. Rotation was in fact slightly earlier than normal to facilitate retraction, and gear selection as I saw the mains unstick. Nose gear partial retraction too.
BTW I was expecting you to be the first to reply😊
Old 02-12-2018, 02:14 PM
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Predictable! ��
if you rig the model now, charge the air and operate, grab a leg each time, does there seem to be power pulling the legs up? Any venting?
Old 02-12-2018, 02:42 PM
Viper1GJ
My Feedback: (19)
Viper1GJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had random valve problems on my SM F-16. Could never duplicate till it would happened again. After a complete tear down to install an new power distribution system I would the red wire on one valve had a bad crimp from the factory and the wire was loose in the crimp pin and would easily slide out. Wa...la...Problem duplicated on the bench. Nearly cost me the jet several times with a gear up landing.
Viper1GJ is offline
Old 02-13-2018, 02:07 PM
c_makhija
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Dave Wilshere View Post
Predictable! ��
Dave.. off on a flight, back home only Friday. Will check and revert.
Old 02-14-2018, 11:24 AM
David Gladwin
David Gladwin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have two Airworld Hawks Jettronics gear valves work perfectly at 10 bar,150 psi .sluggish at 125 psi.
My Skygate Hawkgear works perfectly at10 bar using the Intairco valve unit which also includes speed control , superb unit !
However if your units used to work I suggest:
Injecting some BVM thin lube into your air system to lube the cylinders. Use a water trap in your compressor air line.
Cleaning all moving parts then applying BVM dry lube. This gives me perfect results and my guess is it will solve your problem!
David G.
David Gladwin is offline
Old 02-15-2018, 11:57 AM
c_makhija
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello David,
Actually went up to 140 PSI for 2 flights with no luck. The gear when connected direct to the pump operates with minimal pressure and smooth.
Water trap has been there from day 1. Suspect the valve as even the nose did not retract.
Any experience with the JMP high flow mechanical valve?
Regards
Chatty.
Old 02-15-2018, 12:55 PM
aehaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sometimes valves work best with lower pressures. They may be made to work against the air pressure when actuated. Does the gear work well with only 75 PSI? The BVM air valves are this way - mine were too slow at 100 PSI but work fine at 75 PSI.
aehaas
aehaas is online now
Old 02-15-2018, 01:49 PM
rhklenke
My Feedback: (24)
rhklenke's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm surprised that no one has suggested that you might have some crap stuck in the valve. I've seen that before causing slow, or no, gear retraction...
Do you have another spare valve around that you can put into the system temporarily and see how the gear works?
Bob
rhklenke is online now
Old 02-16-2018, 12:28 AM
David Gladwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by c_makhija View Post
Hello David,
Regards
Chatty.
Hi Chatty,
can only conclude itís the valve.
I have no experience with JMP but I guess it will be top quality.
However, as I said earlier Jet Tronics works perfectly on my AirWorld Hawks and the Intairco dual valve system, gear and doors, has proven perfect for my SkyGate Hawk !
So so itís a valve change!
David
Old 02-16-2018, 06:36 AM
kevinthoele
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These valves are highly susceptible to moisture. I know you say you have a trap but I will bet it is full of moisture. I did an experiment in Houston and the trap lasted less then one day before full of moisture. Best way to fill tanks is small scuba bottle with stage reduction for pressure
or change to mechanical valves like JMP UP style. Good luck with your diagnoses and gear working flying!!!!!
kevinthoele is offline
Old 02-16-2018, 06:45 AM
aehaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I only fill my air tanks from a small scuba tank, no moisture at all. Of course you need a regulator and pressure adjustable valve you can set to 100 PSI or so.
aehaas
Old 02-17-2018, 08:11 AM
c_makhija
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Guys,
Valve changed. Need to assemble the hawk and see if there is any change. The problem is can actually be tested 100% in flight. This had the older orbit valves, now the evojet.
Regards
Chatty.
Old 02-17-2018, 08:15 AM
c_makhija
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guess your right, will change to the JMP valve if this one does not deliver.
Been using the BVM mechanical valve for more than 10 years now in all my sport jets, never a hiccup.
Chatty.
