Frsky radios with jets?
Reply
Old 03-13-2018, 04:22 PM
geneh-RCU
geneh-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Frsky radios with jets?
Anyone use the Frisky X10 or their other radios with turbine planes? Have they worked out good or any problems?
I wanted a new Futaba SZ16 but can't get any Futaba radios or receivers now.
geneh-RCU is offline
Old 03-13-2018, 04:58 PM
erh7771
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Been using mine for turbines for over 2 years, not one issue, more options than I need and 16 channels on tap with simple SBus to PWM converters.
Plenty of vids on YT to set openTX options but loaded with templates to KIS
I use Taranis, don't care about gimbals etc so have never switched to any of the horus line
HK has a sell on the enhanced X8R RX's with free shipping
erh7771 is offline
Old 03-14-2018, 01:48 AM
Air Works
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is an interesting video on YT on how good the range is
Air Works is offline
Old 03-15-2018, 03:24 AM
Henke Torphammar
Henke Torphammar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go Jeti :-)
Henke Torphammar is offline
Old 03-15-2018, 04:56 AM
Dr Honda
Dr Honda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was a fan of Futaba back in the day (late 70's to the early 2000's)... but then when 2.4 came out... they took FOREVER to get on the band wagon. From there... I switched to Spektrum. But a couple years ago, I had a few losses for unknown reasons, and they had a bunch of issues of RF decks failing. (in the DX8 and DX18) so I switch to Jeti. I love the feel of it.
WITH THAT SAID.....
I know a bunch of guys who use the Taranus radios, and have good luck with them, and over the last few years, they have really improved. I guess my only issue with them is hit-n-miss customer service. Also... I would have to verify any part with use in something else for a while before I would put it into a turbine. Just before Xmas, I was going to buy a QX7, and put a multi protocol module in it. (but the kids toys had to come first)
I'm not a guy to say "It's cheap so it sux"... but I would want to prove it to myself before I put it into anything of value. Heck... I bought a $170 Jeti Assist Rx, and put it into a $40 electric 3d model before I felt comfortable enough to put it into one of my jets. (it was new, and potentially could take over control. Had to prove function to myself)
So.... buy it... mount it in something cheap... make sure it would and doesn't do anything goofy... and once you are happy... put it into a jet.
Dr Honda is offline
Old 03-15-2018, 05:31 AM
ChuckC
My Feedback: (24)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To Tony's point - a long time ago electronics , GENERALLY most often failed in "infantile failure" mode, which speaks to the very valid concept of testing it out in something cheap that you won't cry over if it died. I still test/burn in my servos that way and because it's easy to do so.
However, I don't hear or see a lot about such failures any more and wonder how applicable said failure mode is any more (?) In fact, it seems very rare to see failures of most kinds of electronics, though they happen, compared to back in the 90's and 2000's.
Funny - I went down the same road as Tony with first Futaba and now having switched to Jeti; I love the Jeti and get /like Germanic programming logic (if you call it that).
ChuckC is offline
Old 03-16-2018, 05:06 AM
Henke Torphammar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WITH THAT SAID.....
This was the longer versions of my reply Thought I could as well do the long one too.
I got my DS-16 Jeti 5years ago. Back then it was 16channels. During the years they added more channels via updates, so now it does 24ch. Also added capability of LUA, Jeti and 3rd party sensors and interfaces have come to market and I really feel every time I use it that its so superb. Never had that feeling with other radios. Coming from JR with the 10X, cool with touch display but reall expensive and a big compromise as it did only air, not heli(!!) from that to the PCM9 which was a downgrade in quality but gain in programming... then over to DX8 to get proper 2.4ghz, but the DX8 is a plastic joke, no quality feel there. Went Jeti, and wow - still wow after 5 years. I se no need to switch to the new DS24 as I still love the 16. I just upped my battery from the stock 3200mAh to a 7000mAh and now I charge once every 4months, and I fly EVERY SINGLE DAY after work. Been doing so for 27 stright weeks now.
My helicopter is all programmed via the DS16, both the gyro system and the ESC. Really cool. This with a 5year old Tx.
Old 03-16-2018, 08:05 AM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have also been flying Futaba for ever.
But my next radio will most likely be the Horus X10S
I like the dual battery and dual rx power box for 16 channels that they make.
You connect the 2 rx`s to the powerbox with a sbus cable on each rx, and then have 16 channels out, with redudant battery bus, and also rx redundancy, and diversity..
I like the adea that you can place one rx in the nose , and one ai the top of the plane, sŚ they sort of work like satelites, and it chooses the best reception.
The TX allso has 2 internal antennas, and one external.
ID:	2259441   Click image for larger version
ID:	2259442   Click image for larger version
ID:	2259443   Click image for larger version
SJN is offline
Old 03-16-2018, 12:09 PM
ravill
ravill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not on your life.
ravill is offline
Old 03-17-2018, 12:51 AM
HarryC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like the adea that you can place one rx in the nose , and one ai the top of the plane, sŚ they sort of work like satelites, and it chooses the best reception..
It is a blatant rip-off of the Jeti central box 200. Frsky is cheap because Chinese just steal western work. They even cut and pasted paragraphs from the Jeti's instructions into the Frsky one. Disgusting. They should be boycotted.
http://www.jetimodel.com/en/katalog/Central-Box/@produkt/Central-Box-200/
HarryC is offline
Old 03-17-2018, 04:24 AM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have not looked int othe Jeti stuff. It sure looks similar.
At least it will work great then :-)
Copyright is not a word in the chinese dictionary
SJN is offline
Old 03-17-2018, 08:06 AM
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sightly Amused
Central Box 200: JETI model s. r. o.
Harry - Your indignation is slightly amusing to me having been copied years ago. The Japanese companies did not build a good radio until they copied US designed radios in the late "60's. Who boycotted the Japanese companies?
sidgates is offline
Old 03-17-2018, 08:33 AM
Air Works
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Struggling to understand why people have a downer on affordable gear if its reliable and has the same features as other high cost radios. As for copying it has two sticks a bunch of switches and a color screen as do many other radios
Old 03-17-2018, 08:36 AM
rcflyguy_26
My Feedback: (8)
rcflyguy_26's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So you're ok with someone copying want every you do for a living, making it cheaper so you lose your job....
rcflyguy_26 is offline
Old 03-17-2018, 09:16 AM
ravill
ravill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I donít know if itís reliable and Iím not into being a guinea pig.
And Iíve tried the HK stuff, and yes even in $20k+ Jets that Iíve spent years building. But only when nothing else would work and never in critical areas.
You asked, I answered.
ravill is offline
Old 03-17-2018, 11:05 AM
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built model radios control sets for 16 years, closed in 1983. When I stared flying high value models a few years ago I started looking for the best RF link I could find with airspeed sensors. At that time I settled on Weatronic for RF link and the promise of good telemetry. The RF link has been very reliable but the telemetry was very expensive and the company didn't have good support in the US. Four years ago I and 2 close friends decided to try the Taranis. All 3 have been faultless except for some minor mechanical issues. We did not like the feel of the gimbals and that was solved my hand making metal centering arms for the gimbals.
I like Ravill am very cauious about what I test a new radio in. After 4 years I have put the Taranis in a Top Gun F-15 with turbine but have not had the weather to test fly it yet. I have flown the Taranis in everything from foamies to 1/4 scale models at this point. Several in my local area have purchased the Taranis since we did and one guy received a defective (short range check) receiver which was immediately replace by Aloft.
When a modeler shows an interest in the Taranis the first thing I do is show him the programing. It is hard for some people to grasp but very powerfull.
sidgates is offline
Old 03-17-2018, 07:58 PM
erh7771
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FrsKy RXs and TX mods with RSSI has been out for a while nearly ...10 yrs,
The mods were known for RSSI and no let go lock before Frsky went into controller hardware and kept the software FOS starting with Taranis
Industry followed the feature set relative to price but it started with a no let go frsky RX \ TX and RSSI
erh7771 is offline
Old 03-17-2018, 08:26 PM
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Need explanation
What do you mean by "no let go lock"?
sidgates is offline
Old 03-17-2018, 08:39 PM
erh7771
My Feedback: (30)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wont let go of a lock between RX and TX while flying some miles beyond sight without using a LRS.
erh7771 is offline
Old 03-18-2018, 01:16 AM
JohnMac
JohnMac's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well Said.
JohnMac is offline
