Reload this Page >
Maj. Woody's Skymaster 1/5 F-86
Old 08-09-2018, 01:57 PM
  #76
two dogs
My Feedback: (12)
take off slats and flaps for takeoff........full flaps and slats for landing........haven't tried to land with speed brake deployed. don't like slow on landing f86, can be snappy at slow speed. That is why I programed some crow on wings to give wings a little wash out....works for me.
I do have speed brakes mixed with wheel brake when full flap deployed.....so once I apply brakes on runway the speed brake also deploys to help shorten roll out.
Old 08-10-2018, 01:21 PM
  #77
Jetpilot24
My Feedback: (21)
Two Dogs
I have flown Sabres for most of my jet flying career. I have always landed with the speed brakes deployed and I don't recall any snappy situations on landing. Most landings where on the mains and hold the nose high just like the full scale. Here is a video of KY Jets with an HP Jets F-86. Also the first 1/5th Skymaster I had I would land with everything out and it was rock solid on landing. Only reason I do not have it any more is I had the right flap fail on take off. It ended ugly. You should not have any issues if you deploy the speed brakes in flight for landing.
Old 08-10-2018, 01:22 PM
  #78
Jetpilot24
My Feedback: (21)
Dominic Get yours out and started. Just don't over think it. You will love the Big F-86
Old 08-10-2018, 03:15 PM
  #79
ravill
ravill's Avatar
Indubitably!! Sabres are, all in all, sweethearts!!
Old 10-27-2018, 09:49 AM
  #80
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
This is the Shipping Container for my F-86. I guess I am committed to the build now LOL!
Old 10-27-2018, 09:52 AM
  #81
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
The first order of business was to bolt together the fuse and tail and see if I could get this thing out of the basement. It just makes it!
Old 10-27-2018, 09:56 AM
  #82
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Next I slid the wings on so I could verify everything matches up. This jet is massive and the pictures do not represent just how big it is!
Old 10-27-2018, 10:00 AM
  #83
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I am going to be taking this build nice and slow and actually try to enjoy the process. I made a job of building the two Flashes last winter and it burned me out. In the end it was worth it as I had a blast flying those jets this year. Both are safely tucked away for next season so if the Sabre does not get finished this winter that's OK with me. When it is done, it is going to be incredible. It has so many scale features and its massive size gives it such presence! I am not sure if I am going to take on the added workload of a build thread but well see how it goes.
Old 10-27-2018, 10:07 AM
  #84
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Does anyone have the overall length of the two wing spars (carbon rods)? On mine, the small front spar is 19 7/8" long leaving 3 7/8" sticking out each side of the fuse. My front spar is 28 3/8" long leaving 8 3/16" sticking out each end of the fuse. The reason I ask is that the rods are not as long as the sockets in the wing and I want to be sure they are long enough to engage the ribs in both wings. I had a FeiBao L-39 that after 200 flights the wing started to sag in flight. When I researched it, it turned out the spar was too short and did not engage the plywood ribs in both wings. Hard to believe I flew 200 flights like that with only the Fiberglass tube in the wing providing the strength. Anyway I want to be sure I dont run into that with the Sabre.
Old 10-28-2018, 05:00 AM
  #85
Vincent
My Feedback: (61)
Vincent's Avatar
I built mine in Feb 2015 and have flown it many many times. If you want the main doors to stay closed go with a double air cylinder on each. I have since converted my gear to elec (down and locked) and have servos on the doors so everything snugs up tight. I started out with a full house setup using slats and speed boards. I abandoned them in probably 10 flights. The plane lands beautifully on just full flaps, the rest is just bling. If i were to order another one i would get the lightweight airex version without the slats, speed boards and sliding canopy. The plane is a wonderful flyer in any configuration though...enjoy!!!
Vin...
Old 10-28-2018, 11:13 AM
  #86
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Thanks for sharing Vin. Your Sabre looks great!
Old 10-28-2018, 11:25 AM
  #87
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I have had good feedback from you guys on a number of things, one being the need to lengthen the nose strut. I am fortunate to live only a few miles from my long time friend John Mesolella of Matrix Machine. I took my nose gear over there today and was going to have him machine a collar and a plug to move the inner strut down. When we started measuring, I did not like how much of the inner strut was left inside the main strut. John came up with the idea of leaving the inner strut fully engaged as delivered, but instead extending the oppose end by the wheel. in no time he machined an extension out of steel that fits into the inner strut on one end and into the nosewheel loop on the other. My tire now just clears the door. I cleaned and lubed everything and put loctite on each screw. I also tuned the amount of oil in the front strut to give a good balance between firmness and range of movement. Once the jet is done and fully loaded, I will have to see how much sag the front strut has when sitting on its gear and if too much, I will add more oil.
Old 10-28-2018, 01:03 PM
  #88
Jetpilot24
My Feedback: (21)
Dom
You will love the Sabre when its done. You saw how well mine flew at Perry.
Enjoy the build, don't get too hung up on assembly and there is no reason you should not be ready to fly it next year.
Remember mine was all white Gel coat. I started mine in Oct of last year, nothing was installed. I installed all the doors with double air cylinders, speed brakes and leading edge slat hinge system in the wing and slates. Also had to assemble the sliding canopy system too. I painted it and every thing is paint except the nomenclature and Statue of Liberty and had it ready to fly by spring.
You are off to a good start
Joe Lewis
Kingtech
K-80, K-140, K-180
Owner
Old 10-28-2018, 01:59 PM
  #89
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Thanks Joe. I spent the rest of the afternoon programing my radio so that I can be ready for the install. I think I am going to start with the wings.
Vin do you think you could measure the length of your front and rear CF Spars?
Thanks!
Old 10-28-2018, 05:35 PM
  #90
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I forget to mention that John can make that nose strut extension for anyone who needs one. Just give him a call to order.
Old 11-04-2018, 04:49 AM
  #91
Jetpilot24
My Feedback: (21)
Dom
Here is a little more inspiration
Joe Lewis
Kingtech
K-80, K-140, K-180
Owner
Old 11-04-2018, 04:23 PM
  #92
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Sweet. I am glad I did not sell it. This is one sweet ride. Did a little work on it yesterday. I replaced the plastic main gear door hinges for BVM Aluminum hinges. This was a 4 hour job considering The plastic hinges were hysoled in between the door skins. I had to carefully grind them out. Same for the opposite side in the fuse. I also added a rear door cyclinder tab for my Robart door cyclinder. I have the stock SM cylinders on the front of the doors and the robarts in the back. I am going to swap the hinges on the nose doors as well. If I was ordering this kit from SM, In would have opted for the BVM Aluminum hinge option. The package I bought from Cheif had every option but this one. No building at all today. I flew my Cessna instead. Going slow with the Sabre and actually enjoying the hobby pace vs the like a job pace.
Old 11-05-2018, 01:02 PM
  #93
ravill
ravill's Avatar
Excellent!
Old 12-01-2018, 09:04 AM
  #94
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Hi guys.
I have decided to do a complete build thread. I need another couple days and I will have one wing panel complete. At that time I will update the thread with detailed photos and build notes. It has been an enjoyable build so far and the fact that I have not established a completion date keeps it fun. The funny thing is I am doing just as much building as I did with the Flash. Psychology is a funny thing.
Old 12-01-2018, 09:07 AM
  #95
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Special thanks to Joe Lewis who has my sounding board to bounce ideas off of. Having built two of these himself, he has been an excellent resource for me.
Old 12-01-2018, 01:01 PM
  #96
Jetpilot24
My Feedback: (21)
Dom,
Great to hear you are doing a build thread. Keep it lite and don't burn yourself out.
Joe Lewis
Kingtech
K-80, K-140, K-180
Owner.
Old 12-01-2018, 01:46 PM
  #97
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
In you case Dom , maybe is psycho... LOL
I knew you couldn't contain yourself...you enjoy it too much.
looking forward to your photos.
Old 12-02-2018, 03:40 AM
  #98
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
LOL Rich!
Old 12-08-2018, 03:39 PM
  #99
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
My build started with swapping out the plastic door hinges for BVM metal hinges. Here is how it comes.
Old 12-08-2018, 03:41 PM
  #100
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
First I removed the hinges from the Fuse and cleaned up the plywood with a sanding block.
