Questions about mixing on JR 12x
My Feedback: (49)
I have a 1/6th scale SM F-16 that I purchased from a prominent well know modeler. I bought it complete with the transmitter. Today I was looking thru tx programming and I find a couple of mixes I don't understand. They are:
Mix #1 Aux 5 to Aux 5 it shows Pos0 plus minus 0 and below that minus1 pos1 has minus 38 and plus minus of 0. on this airplane Aux 5 is for an opening and closing canopy system.
Mix 2 Thro to Thro with no values (all 0%) no offset. thro stick inhibited. From what I know and understand about mixing this mix is doing NOTHING, since there are no numbers entered for position 0 and 1 ?
I have heard of these type mixes where a ch is mixed with itself but I have never understood the purpose and what is being accomplished.
I can send pictures of these two screens if need be.
My Feedback: (49)
While that is a great idea for safety it does not appear to be the case. Aux 5 is moving on the monitor screen with gear switch up or down. Thanks. I can send pictures to a cell phone or an email address. I don't know how to put them on my post, if that is even possible. I might need the help of an 8 or 9 year old to show me ho and I don't have one of them around to help me.
My Feedback: (24)
Almost all more modern radios have a "function" menu where you can set any stick, switch, or knob to control any channel...
Bob
My Feedback: (41)
I've not run across that particular mix being used to disable the normal channel function. It's been awhile since I played with my 12X and it seems to me that all you need to do is "Inh" that channel in the setup screen. Then it makes it available to assign to a mix like flaps with dual servos.
Or am I just remembering incorrectly? Not hard for an old guy to do..... lol
I have a 12x and woud never sell it since its a simple but very easy programing radio. When you go in to the mix function you have mix1,mix2 and the restof them. when you go into these mixes , its simply to inh or activate the mix. Example mix 3 you might get THR to THR , now you get the chance to change the slave and the master chanel and then the switch its going to use , actualy pretty simple once you play with , and if you go back it to it
If you dont have a manual let me know , i think i might have a digital version.
My Feedback: (7)
As I recall, mixing a channel with itself either increases or decreases it's output based on whether the mix value is positive of negative. For example if you wanted nose wheel steering disabled when your gear is up you could use a steering to steering mix with a -100% value, activated when the gear switch is in the up position to force the steering channel to be centered when the gear switch is in the gear up position.
As another example I believe if you had a control that wasn't supported by dual rates, if you wanted additional travel you could create a mix of X to X with a +20% mix value activated by a switch to get an additional 20% travel from channel X whenever then switch activates the mix.
