Extending jet pipe a little
Calling those wiser & more experienced than me.
I'm building a scratch built jet & the jet pipe is a little too short (my bad).
It's a Wren thrust augmenting pipe but it only needs to be extended about 2 inches to clear the back of the model.
Is there any reason it cannot be extended with another strip of stainless wrapped around the outside of the pipe
& secured with some stainless pop rivets inserted from the inside of the pipe?
The outer pipe is litho as per Wren instructions, no issues there.
Thanks in advance.
Thanks in advance.
I have extended a pipe before, but I spot welded the extension in place.
I think using pop rivets could result in a several possible issues.
(1) the rivet tool is likely to be too big to fit inside the pipe without distorting it quite a bit.
(2) It is possible that the rivet heads in the hot gas flow could cause uneven heating of the pipe and lead to warping and/or failure.
(3) Your extension is still going to have a seam that will need to be joined. If you do that with pop rivets you are going to end up with a lot of rivet heads in the flow at the very back of the pipe.
I would look for someone who can spot weld it for you.
