Powerbox HD extension Lead wire
Reply
Old 10-16-2018, 08:49 AM
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Powerbox HD extension Lead wire
In the UK Powerbox servo wire has become the number 1 favourite in Jet models, they have now produced a larger version suitable for the bigger models so invogue
The power cables are larger 0.5mm˛, with the signal a smaller gauge.The Premium™ MAXI servo cable is the thicker variant of the familiar Premium™ cable with a conductor cross-section of 0.35mm˛. In this case ‘thicker’ means that the current-bearing positive and negative conductors have a cross-sectional area of 0.5mm˛, while the signal conductor’s cross-section is 0.3mm˛ in order to save weight. This makes the Premium™ Plus cable ideal for installations where relatively long leads have to be deployed in the wing or fuselage for high-performance servos.
This insulation produces a weight reduction of about 30% compared with the conventional PVC.
Dave Wilshere is offline
Old 10-18-2018, 09:10 PM
Airliner-rc
Airliner-rc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use this wires like servo extension. Good choice.
Airliner-rc is offline
Old 10-19-2018, 10:15 AM
JoeJr1485
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried this wire and bought it from dreamworks but ended up having to rip it all out from my FB Viper. The wire sleeve kept braking. Maybe I miss understood which one they have. the runs that I needed to reach back to the rudder and elevators were long so with a mix of maybe the wire DW is selling and the length of my servo extension gave me a bad tast on the wire. I wouldn’t mind trying to use it again but maybe the new size that PB offers
JoeJr1485 is offline
Old 10-19-2018, 10:35 AM
Airliner-rc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
maybe you can not making right connections
it is very good wired.
Old 10-20-2018, 03:11 AM
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use the PB wire and connectors exclusively. Best I have ever used.
Bob_B is online now
Old 10-20-2018, 03:22 AM
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used PB wire exclusively with their connectors, very good product, I will get that bigger wires if I get into bigger then a 2 meter’ish jets.....no problems at all with the wire solid connection, the right crimper does help.
Dansy is online now
Old 10-20-2018, 07:26 AM
Airliner-rc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
100% agreed
