PB Mercury SRS gyro question
I’m building a T3 and haven’t been using any gyros in the past. I like using the Spektrum transmitter with the Powersafe receiver. It was recommended to me to use the PB Mercury SRS Gyro. I’ve heard from someone that it’s a bad set up that’s crashes a lot of Jets. Just looking for some feedback before I make my decision. Thanks Tim.
You have been given bad info unless it’s Spektrum related. The Joker and Mephisto pictures I have posted today both have PB Mercury’s fitted. On the field today there were also other Jets flying with Mercury’s fitted. It’s our biggest selling PB unit and I’ve not had a fault on one yet.
Dave
Dave
My Feedback: (41)
No, the Mercury requires two rx's in this case it would be satellite rx's to do the job. It has it's own dual power inputs, battery isolation, regulated voltage out put, gear sequencing and all sorts of nifty things it will do. If you want to use the PowerSafe rx, just pick up an AS3000 for the rx. It's got a gyro in it, not quite as sophisticated as the one in the Mercury but it's only $65.
I have one jet, a T-One with a PowerSafe rx which I've not flown yet. The others have either a Mercury or a Royal SRS using GPS sensors as well. Those allow the gains to change with model speed.
My Feedback: (41)
https://www.powerbox-systems.com/pro...rcury-srs.html
My Feedback: (7)
The Mercury has Spektrum RX inside... You only add the 4 satellite receiver antenna's and you are done... No Spektrum anything needed but your transmitter. Gyro system is built in, all's you do is set up what gain rates you want on what surface and go...Get the GPS version, it will adjust gain rates based off of ground speed from the rates you set up... Great system, Love it !!
Dan
Dan
Dan
Dan
My Feedback: (34)
Dan
Dan
Fantastic technology all in one.
I've set up the Mercury in 2 of my jets - rock solid - just perfect.
Tassos
The Powerbox Mercury SRS works great. The Mercury SRS uses two to four Spektrum Remote Rxers. I use three. If you use a PBox Mercury SRS you will totally replace your current PowerSafe Rxer's main unit but you can use its Remote Rxer's on the Mercury, if they are DSMX. SRS stands for Serial Receiver System (I.e. Serial Remote Rxers). If you buy a PBox that is not an SRS model, then you cannot use the Remote Rxers with it.
The AR3000 Gyro also works well with the current PowerSafe Rxers. But, it has to be the new PowerSafe RXers, not the old ones. I have seen the AR3000 work well in other folks jets.
Any gyro or PBox for that matter takes a bit of reading or an experienced person to set up. If you are considering a switch to PBox, you may want to consider spending some time doing some reading. Once you are aware of how they operate and are programmed they are great systems. They have everything you need built right in. You just have to understand each PBox model's features and then decide which model gives you what you want. The Mercury SRS gives you pretty much all you need except the added power distribution of the Royal, etc. The Mercury SRS has 14 channels. Its output programming capability gives you the option to eliminate Y harnesses, etc. (e.g. program same channel to two or more outputs.) It has many other programming capabilities, most of which I do not even use. But it only has 15 output ports, which can become a constraint on a complex system. You just have to do some reading and bench and transmitter setup to take advantage of what it offers. It is not exactly what one would call "plug and play."
I have been using PBox for over 5 years. Once I got used to them, for Jets and Giants, I never looked back.
Gyro
My Feedback: (9)
For me I prefer the power safe with spectrum gyro. But pretty sure that’s because I’m used to it and can set them up in my sleep.
Setting up a mercury in a plane now for a customer and it’s drving my nuts but it’s my first time using one and it’s futaba also and I don’t normally deal with that. All this blue com , , telecom , gps stuff... it’s overwhelming and just feels not needed to me.
That was the way I used to feel about gyros, … Until I was flying the Mercury SRS with the gyro manually programmed, but off. Never had it on. Then one day it was windy as heck and I had inadvertently turned it on and the plane straightened right out. Now I never fly that plane w/o it. Was looking to get a gyro for the Ultra-Flash. But then I figured out that the wind does not appear to impact it very much. So, I stayed with the PBox Competition that was in it. Point being deciding on a gyro kind of depends on the plane and its operator.
My Feedback: (9)
As far as gyros only go its a personal choice and your flying style. Some prefer the exact opposite then I do its all about how you fly and what you want to feel.
My order is best to worst
Cotex is my fave gyro For the way I like to fly this is the best gyro by far.
Spektrum is second on my list Works great and feels locked in
PB 3E is 3rd. Flew an F16 for years with the 3E and it was ok but also flew it with a cortex and like the cortex better.
At the end of the day they are all 3 great gyros and much better then nothing at all.
