Reload this Page >
CB P2B IAS-460 Speed Sensor compatible with CORE from PowerBox Systems
Old 12-09-2018, 02:56 AM
dvcam99
Default CB P2B IAS-460 Speed Sensor compatible with CORE from PowerBox Systems
CB P2B IAS-460 IAS Speed Sensor
CB P2B IAS-460 Speed Sensor from CB Elektronics compatible with all CORE PowerBox Systems telemetry productsFirmware Version 1.0
Dear Jet Community,
we proudly announce our first sensor available and compatible for the new CORE RC system from PowerBox Systems.
If you have any question don`t hesitate to contact us. Please see the web links below.
Use and Features:
  • Easy initial operation ( assemble pitostatic tube, plug in, switch on and read IAS meas result) No PC is necessary! Plug and Play!
  • One-tube- system for easy installation. If you prefer you can build your own scale pitot tube.
  • Measurement range from 30- 460Km/h
  • CB P2B IAS-460 speed sensor design base on our thousand times proofen range of IAS speed sensor family
  • Speed display in kmh (kilometer/hour), mph (miles/hour) or kts (knots)
  • Top-Speed display
  • Compatible with all CORE telemetry receiver (P2B)
  • Full support of CORE sensor priority
  • 40Mhz RISC CPU (fast converting of test results)
  • Automatic nullification (sensor calibration)
  • Small, light, also fits into small models
  • German and English manual is available
  • Dynamic and static pressure interpretation for speed measurement ( comparison to real airplanes)
CB P2B IAS-460 Speed Sensor Specification
Input voltage range: 4,6-10Volt
IAS speed meas range: 24-460Km/h
Speed calculation error: +- 5Km/h
Meas-System: Static and dynamic
Optical signalisation: Yes COR Bus activity
Connection: At the P2B CORE receiver connector
PowerBox CORE P2Bus: Yes supported
Dimensions: B x L x T in mm 31 x 41 x 20
Weight: ensor plus Pitot and tubbing 18gr.
Delivery: Pitot, Silicone tubbing aprox. 50cm and sensor electroncis (complete kit)
*All Trademarks in relation to CORE based products belong to PowerBox Systems GmbH.
Best regards
Dirk
CB Elektronics
First in RC Avionics
https://www.cb-elektronics.com/index.html
https://www.cb-elektronics.com/cb-p2b-ias-460.html
https://www.cb-elektronics.com/impressum.html
