Regular aluminum servo arms for Futaba
My Feedback: (176)
Hi to all,maybe you guys know where to buy regular arm for Futaba servos with no threaded holes for regular Sullivan tupe type push rot kwik-Link
or maybe someone have some and will like to sale them for good use thanks.
Man 1 to 1/2 in quality metal Futaba servos arms are sooo hard to find here. Everyone has long 3D style but most jets only need small amounts of throw and while people just cut endpoints this is the worst thing you can do to a servo. I always try to get as close to the center as possible.
Keith, Thats where using S-Bus servo's works well as you can define the centre and range to suit each individual servo for their application, but still retain full resolution from the stick input.
modtron
Oxford Uk
modtron
Oxford Uk
My Feedback: (18)
I've bought those SWB arms and just drilled an undersized hole whatever distance from the shaft center I needed for whatever clevis I was using and then just cut the excess end of the arm and smooth it out to shape on a bench grinder. Takes ten minutes. Or you can save some money and use this type and do the same thing.
https://www.ebay.com/itm/1pc-1-25-He...-/172159605644
My Feedback: (176)
My Feedback: (18)
Just be aware that some of the ebay ones are thicker so depending on your project you may not want to open up the slot on a servo cover if you're going for a more scale look and more importantly they may be too thick for a clevis and will require a threaded screw with a ball link.
My Feedback: (10)
