Reload this Page >
Powerbox Core radio and set up thread.
Reply
Old 09-17-2019, 10:11 AM
  #151
David Gladwin
David Gladwin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Core
This is what I have working:
On Functions page, assign your flaps to a 3 position switch, say D. Flaps up, 15, land.
Assign a transit time, say 4 seconds. This is for full travel, 2 seconds each segment, I have not yet found a way of splitting them.
Now, assign your Flight Modes to the same switch, again D.
For each flight mode assign a FADE- IN time of HALF the full transit time, so 2 seconds.
( ( scroll up to FADE IN times, otherwise its invisible).
Now observe servo monitor and you will find the elevator retrims at the same speed as the flaps travel.
Bit like a Boeing autopilot retrimming as flaps extend.
In theory it should give very smooth flap transits, provided flaps are not extended at excessive speed.
I still have not worked out the FULL switching logic of Flight Modes ( its obviously very capable, more than I will ever need) ) but I prefer to keep things simple and what I have described above IS working in the workshop.
Be advised , the trim desyn on the HOME page does NOT move at this reduced speed.
Give it a try and let me know how you get on with it !
D.
David Gladwin is online now
Old 09-17-2019, 11:08 AM
  #152
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds good Dave, thanks!
BarracudaHockey is online now
Old 09-17-2019, 12:19 PM
  #153
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It works as you described.... on the screens. Thanks!
AEROSHELDON is offline
Old 09-20-2019, 09:28 AM
  #154
David Gladwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flight modes.
The system was tested in flight today on my PST Reaction. Worked perfectly producing very smooth flap extension to 15 and 50.
Old 09-20-2019, 10:15 AM
  #155
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I need to get that programmed on my Havoc before the maiden.
Old 09-20-2019, 10:16 AM
  #156
AEROSHELDON
My Feedback: (99)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Message me on FB if you get stuck, I might be able to help out.
Old 10-13-2019, 05:59 PM
  #157
felker14
My Feedback: (50)
felker14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AEROSHELDON
Are liking radio?
felker14 is offline
Old 10-14-2019, 07:43 AM
  #158
AEROSHELDON
My Feedback: (99)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, so far so good--only testing in a Avanti Freewing. All has gone well and I am going to install in my Havoc SS and Ultra Flash EVO soon.
Old 10-17-2019, 08:07 PM
  #159
vespino67
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could be possible that an alarm sound or the radio vibrates in a certain position of the throttle stick.?
vespino67 is offline
Old 11-08-2019, 06:17 AM
  #160
David Gladwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Core
Now that flight modes are installed and working I now have a Xicoy telemetry unit connected to the 9 ch rx and to a Xicoy ECU on a PST 1300 powered Reaction.
Everything is working perfectly, one page is set up for engine start, ECU status, batt. Condition, EGT and Rpm with RPM and EGT shown on the home page ( showing trims , timer and rf and battery status) plus an overtemp alarm set at 850 degrees.
Its getting ever better , with more enhancements in the pipeline.
  #161
David Gladwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Core
For any Brits interested in the Core it can be seen working at ABB on Sunday.
Old 11-08-2019, 08:56 AM
  #162
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Turbo Prop info.
Dave Wilshere is online now
Old 11-08-2019, 12:07 PM
  #163
causeitflies
causeitflies's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What do flight modes have to do with the telemetry unit? Does the home screen change with flight modes?
causeitflies is online now
Old 11-08-2019, 12:46 PM
  #164
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nothing! But a lot of people couldn’t set up their models without them.
Old 11-08-2019, 03:26 PM
  #165
Springbok Flyer
Springbok Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
The 2190 fuel; is that the tank volume or the fuel remaining? Also, please explain the two GSU displays.
JanR
Springbok Flyer is offline
Old 11-08-2019, 11:47 PM
  #166
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jan
Yes, fuel remaining, this is a Turbo prop Reno racer we fly and the owner has turbine rpm, prop rpm and temperatures on two widgets. ( I think to fill up the spaces�� ) GSU 2 is showing the turbine idle and prop idle figures.
Dave
Old 11-09-2019, 01:28 AM
  #167
David Gladwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flight modes have nothing to do with telemetry. I merely made the point the Flight Mode update is working v well, and yes, you CAN set up a model without FM s but FMs are a very valuable tool, a function I use on all if my models with flaps. It makes trim changes with flap setting so easy to counter.
Flight modes do not change the page but the Flight Mode STATUS is shown on other pages.
So rather like a Boeing engine bottom screen, I have one page set up with multiple parameters for engine start and then when all parameters have been checked at a stable idle I can then go to the home page ( the equivalent of the Boeing engine top screen) with just RPM and EGT showing as engine parameters as well as timers, trims etc.
There is still a lot to come on the Core but it is progressing nicely. One function I would like to see, a feature of the Weatronic BAT transmitter is the option to assign aileron differential to a rotary knob, enabling in flight tuning of the diff.
Old 11-09-2019, 01:29 AM
  #168
IFLYBVM2
My Feedback: (359)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Basic receiver ?
I am not familiar with the PB line and have a question:
Is there such a thing as a stand alone PB receiver that is suitable for use in a simple model in which a powerbox unit would be overkill ?
Or are you required to run a powerbox regardless with this TX ?
I have jets and warbirds that might benefit from a PB, but also have simple models where it would be overkill.
- Mike O.
IFLYBVM2 is offline
Old 11-09-2019, 01:35 AM
  #169
David Gladwin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The receivers ARE stand alone, if you wish to use them as such, except for the 26 channel unit which is a feed to a Powerbox unit.
On my Reaction I am using a 9 channel receiver plus a 2 function gyro to control rudder and NS giving 10 functions with power from. a PB sensor switch.
The current drains on this model were measured when using a Weatronics receiver and the amperage was WAY below the rated value of the 9 channel receiver, upto 10 amps according to Richard, if I remember correctly.
Current draw on an Airworld Hawk is around 3 amps with spikes when flaps are running upto about 7 and 2 was typical on the Reaction and Revision.
Take a look at the Powerbox web site, its all there.
Old 11-09-2019, 05:02 AM
  #170
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
- Mike O.
From the Powerbox page. But yes, I have several stand-alone installations without the actual power distribution stuff.
Five different receivers are available to match the PowerBox CORE:
PBR-9D
This is a nine-channel receiver with two redundant receiver circuits. The unit features a P-BUS interface for servo and telemetry data, and an auxiliary output which can be configured either as SRXL bus or as channel 10.
PBR-7S
This is a seven-channel receiver with a single receiver circuit. The unit features a P-BUS interface for servo and telemetry data, and an auxiliary output which can be configured either as SRXL bus or as channel 8.
PBR-5S
This is a five-channel receiver with a single receiver circuit and an integral Chip aerial. The unit features a P-BUS interface for servo and telemetry data, while its minuscule size makes it the natural choice for small models.
PBR-26D
This is a satellite receiver featuring two redundant receiver circuits. The unit features a P-BUS interface for servo and telemetry data, and an auxiliary output which can be configured either as SRXL bus or S-BUS. This unit is designed to be connected to our PowerBox power supply systems or a flybarless system.
PBR-8E
This is a eight-channel receiver with two redundant receiver circuits. The unit features 8 PWM servo outputs and telemetry data for battery voltage and RF-data.
With the exception of the PBR-5S and the PBR-8E all receivers have a FastTrack interface with which the iGyro SAT can be easily connected!
Old 11-12-2019, 09:05 AM
  #171
JamesKNMA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An addition to Andy's notes on the receivers: you can bind up to four receivers to the model, in any combination, and it's a very simple process. No master-slave mode settings, etc. on the receivers.
JamesKNMA is offline
Old 11-12-2019, 09:11 AM
  #172
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So most of my model require 10-12 channels and I don't need a powerbox or have room for one, would this be a solution?
Bob_B is online now
Old 11-12-2019, 09:28 AM
  #173
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The "9 channel" is actually 10 if you configure the daisy chain port to PWM output.
Otherwise you can daisy chain the receivers, its easy to do and quite flexible.
Old 11-12-2019, 09:46 AM
  #174
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good to know but a 12 channel receiver would be much simpler.
Bob_B is online now
Old 11-12-2019, 10:51 AM
  #175
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd love to see them offer a 12 channel
