Skymaster F4 lighting help
Reply
Old 03-23-2019, 04:14 PM
kevinthoele
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Skymaster F4 lighting help
I know Steve Stricker built one and put lighting in the wing tips. How did he or anyone route wiring. Are holes needed to be drilled from where to where. Just opened the tip and fitted the details4scale lens (not glued yet)
kevinthoele is offline
Old 03-23-2019, 08:01 PM
ozief16
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ran my wires along the aft side of the rear spar and simply flexed the flaps and ailerons to route the wire
ozief16 is offline
Old 03-24-2019, 06:58 AM
kevinthoele
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ozie
Is there holes in the wing formers to run the wire through or did you have to drill? I have been shinning light through the hole I drilled in the wing tip but cant see light so I thought I must have to drill
Old 03-24-2019, 07:15 AM
f106jax
My Feedback: (16)
f106jax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kevin, are you working on the 1/6 or the 1/7.5 version?
f106jax is online now
Old 03-24-2019, 07:48 AM
ozief16
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good point 106
Both Steve and I have the 1/7.75 (unless heís got a new one)
Iím pretty sure I had to use a long drill bit to punch through one rib in there to get to the TE of the wing. I I think I slipped roughly a 3/16Ē bit in the crescent shaped hole for the light, aimed it straight to the TE (so roughly 45 deg relative to aircraft heading from the front left towards the aft right or vice versa) and only found one rib in the way. If I remember correctly (Iím not home right now) that aft spar doesnít go all the way out so after going through the offending rib, I came around the outboard end of that spar with the wire.
Because tou can clearly see that aft spar with the flaps down I tack glued the wires in the top skin/aft spar intersection so you canít see the wires with the flaps down
i can check all of this and give you pics in a day or so if you need
Dave
ozief16 is offline
Old 03-24-2019, 08:00 AM
kevinthoele
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Lighting
Originally Posted by ozief16 View Post
Good point 106
Dave
Working on 1/7.5 size
Old 03-24-2019, 09:34 AM
f106jax
My Feedback: (16)
f106jax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, didnít put lights on my 1/7.75, just the 1/6. Looks like Ozie has the answer for you.
Old 04-06-2019, 08:02 PM
kevinthoele
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Controller
what wire is positive? Does it go on top or bottom of controller when plugged in?
Old 04-07-2019, 04:52 AM
f106jax
My Feedback: (16)
f106jax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
White is the common and goes towards the bottom. No damage if you plug one in wrong, the light just wonít come on.
Old 04-08-2019, 04:58 AM
kevinthoele
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally got both installed this weekend. First one was time intensive but after I learned how to bend wire to use as fish the second was easier. Lens all glued with silicone and after putting to AA across wires they light up!!!!!!!!!!
