Need information on small turbine jets
#102
Well, I understand that now there is additional verbiage now specific to turboprop; what I was mainly curious about is how and why the wording "turbine powered model" ever excluded turboprops before the turboprop waiver was created. It's not relevant to this discussion though, as I mentioned I just didn't know such a thing existed and would have never guessed that a 12lb turboprop doesn't qualify for a turbine fixed wing airplane until this thread. Carry on!
#103
My Feedback: (24)
To-date, I don't know if any turbo-prop waivers have been issued, but I'm not sure.
The situation with small turbines is also similar in that they've really just come about fairly recently in a readily available and reliable way...
Bob
#105
#107
Perhaps because some of us belive that much of the certification processes for things like this are inherently governmental, for the following reasons:
First, AAA doesn't "waiver" sports car drivers for operation on PUBLIC highways. BoatUS doesn't "waiver" speedboat operators for operation on PUBLIC waterways. And AOPA doesn't "waiver" operators of P51s or other high performance aircraft for operation in the PUBLIC airspace. Thus I do not believe a private dues collecting organization, AMA, should "waiver" operators of recreational sUAS for operation in the PUBLIC airspace.
Secondly, one of the fundamental aspects of federal law (i.e. FAA) is the concept of equal protection. Namely, ALL citizens are able to enjoy the rights and privileges under the law as all other citizens. So now we have a law that is structured such that to fly a FW turbine under recreational rules, one has to be a member of a private dues collecting organization. Why is that? Because AMA has said they won't evalute/waiver/etc. non-members. And because of that, you now have two classes of citizens under the law ... those who are members of a private dues collecting organization (i.e. non-goverment) and those who are not. That creates an equal protection clause basis as the regulation in question is a federal one. It doesn't matter that 107 is an option. The point is that whether it's 101 OR 107, both have to be available to ALL citizens.
The best thing that AMA could do is create a process to evaluate, "waiver", or pick some other term both members and non-members. S ame concepts for LMAs as well. All it's going to take is one non-AMA member with some $$$ to file suit in Federal court. After all, look at what Taylor was able to do.
#109
My Feedback: (54)
My first turbine was about 12 years ago. The engine was a Mamba 11# thrust engine. I had to use and maintain a scuba tank for the air to spin the turbine wheel for start. Not to mention transporting it to and from the field and in and out of the trailer in Florida’s 92-94 degree summer heat. A glow driver for the glow plug, along with having several high end glow plugs when you burn the current one up. A propane valve and tank with the connection fittings. They were a B to start. There was a trick so that you didn’t blow the propane flame out adding air and propane in the proper flow, if you got it to light off. The previous owner was demonstrating how to start it. The first POP I heard on a start sounds like a shotgun going off. I ran for my life, because of the propane, jet fuel and ignition. 😂. All he did is laugh. I gradually got used to the popping, but sometimes it would take me 45 minutes to start. By then, I didn’t feel like flying. Most engines are now kero start. Push a couple buttons and stand back and watch. Now anyone can start a turbine with little training.
IMHO- drop the weight limit and be open from 0# to 55#. A lot of this also has to do with how much money a guy can afford to put into the ground and walk away. It also has to do with what the manufacturers are producing and selling. Getting rid of the 12# limit will make it easier on everyone, yet still safe.
#110
Really? Then let me throw this at you. A guy shows up at a flying field with a turbine powered Eagle. He's not an AMA member but wants a turbine waiver. Would he be able to get one or would he be forced to join the AMA first? What other hoops would he need to jump through to get his waiver?
#112
My Feedback: (24)
For anyone interested in the actual contents of the law on recreational use of unmanned aircraft, the main portion is below. If you want to see the entire text of the bill, see paragraph 349 of the full law here:
https://www.congress.gov/bill/115th-congress/house-bill/302/text?q=%7B%22search%22%3A%5B%22FAA+Reauthorization %22%5D%7D&r=2#toc-HFC2BF962EFA14270B797E485483D072C
Note that there is no specific prohibition of the operation of turbine-powered model aircraft anywhere in the law. The AMA's "waiver" program is to qualify for operation under the AMA's set of community based safety guidelines. Anyone not wanting to utilize those is free to develop their own. The law even spells out how to do that...
If you don't want to follow the AMA safety guidelines, you can operate under "all statutes and regulations generally applicable to unmanned and manned aircraft systems" - meaning 14 CFR Part 107, that *also* does not prohibit turbine-powered unmanned aircraft.
Bob
Bob
#113
My Feedback: (24)
AMA insurance is *primary* for site owners and is only provided for AMA members - just like AAA, AARP, etc. If that person hurts someone or himself, then the site owner could be liable, and the leases for most AMA club fields, which generally are on private land, state the only AMA members can fly there, for that reason.
AMA fields on public land are somewhat different, but actually most localities now also insist on AMA membership for the liability insurance coverage.
Bob
#114
A little history;
This comes from my 6 years as JPO President.
Why is there a waiver in the first place? When a model turbine engine first became commercially available someone on the AMA EC saw a nightmare scenario: someone putting a JPX in a Parkinson Regal Eagle (I am not making this up). To stop this, they just banned turbine models. You could get special permission from your AMA District VP to fly on a day at an event. They then put into place the waiver to allow other to fly with far less restriction. Just get 50 flights on a 150 mph ducted fan or pylon racer and pass the written test and you were good to go. The constraints placed in the safety regulations of the day pretty much prevented the nightmare from being built. This system went on for a number of years with little change. During this time Jet Pilots were few and considered to be something of an unknown. About 17 years ago Don Lowe, head of the AMA safety committee and past AMA president, went to a jet rally and realized that many of the regulations made no sense (written around the JPX, which was no longer used). Don contacted JPO and asked that we help rework the Regs. During that process The AMA EC and the Jet pilots of this country were better introduced, and things started working much smoother.
There is a sort of a good reason the wavier is not going to go away. At one time the AMA felt that turbine models represented a higher risk, and they acted to address that risk. If there were an accident today that resulted in a lawsuit the AMA can, justifiably, say that they understand the risk and have a process in place to minimize it. If the wavier process went away the other side could say the AMA knew of the risk but quit acting to minimize it. It does not matter any longer if there is more or less risk to flying a turbine model, a precedence was set in the past that dictates today’s actions.
I do not agree with the 12 pound rule, it is a complication not required for the true need of the waiver. The wavier shows that the pilot demonstrated reasonable pilot skills and knowledge of the system. If someone qualifies on a light turbine then proceeds to a heavy scale jet, if he crashes it will be on landing, and no different than someone learning on a foam electric and trying to move on to a heavy warbird.
I would recommend that JPO work to remove the 12 pound rule sense upon further examination we do not see a true impact on safety. Ultimately safety is in the hands of the members and we must assume that they will apply some level of common sense.
Steven
Steven
#115
https://www.congress.gov/bill/115th-...97E485483D072C
Bob
Bob
You're selectively quoting. The aircraft is operated "in accordance with..." part is operable. As of now, there's arguably only one set of CBO rules. And those rules say that to operate a turbine, you need a waiver. And as Andy said, to get a waiver you have to be a member. Once there's other CBOs, maybe the rules change, but until then, any citizen has equal protection under the law, in this case 101. Equal protection is NOT defined as using 107, that's a different section of law. All of the citizens get equal protection under all laws, not just part of one or part of another.
As for the towing etc. example. Andy again makes a bad comparison. One doesn't have to be towed in order to operate on the PUBLIC highways. Nor does one have to have towing service to operate on PUBLIC highways. The AARP discounts thing is laughable, as that's a an affinity program. And yet again, one is not required to have AARP to operate in the public ... well ... anything.
#116
My Feedback: (9)
A little history;
Steven
Steven
well said!! I fully agree. Get rid of the 12 pound rule. A turbine is a turbine. You should not have to spend a ton of money on bigger stuff if all you want is a smaller model.
#117
My Feedback: (24)
I keep coming back to the example of a hand-launched Funjet with a P-20 being potentially allowed as a waiver aircraft - which I'm not sure is appropriate as a demonstration of reasonable skills. In addition, there are portions of the requirements for successful completion of the waiver flight that are not possible with a hand-launched Funjet, or similar aircraft.
The turbine rules make a distinction for "hand-launched aircraft which have no undercarriage and with a flight weight under 7.5 pounds wet" - with respect to brakes in this case.
So what about applying the above statement to the requirement for the aircraft to be used on the waiver flight - i.e., "the aircraft must be over 7.5 lbs wet, have a rudder, an undercarriage suitable for rolling takeoffs, brakes, and a ground steering system."
Thoughts?
Bob
Thoughts?
Bob
#118
My Feedback: (24)
+1
That's a funny story! I think the issue you had was the fact that it was a Mamba.
I used to have a bunch of AMT air-start turbines (and operated a bunch more when I worked with NASA), and they were easy and a blast to start - seriously. A blast of air to spin the wheels, hit the propane until it lights (usually just a wosh, not a pop) and then hold both wide open until it comes up on the kero.
The sound was also unmistakable and really cool! I should have kept one of those engines - although I got tired of having a scuba tank rolling around in my garage.
Bob
#119
Thoughts?
Bob
Thoughts?
Bob
My point is that your "evaluation" is largely arbitrary and subjective. Even worse as JPO doesn't have any sort of standardization among those signing off waivers ... which means they're even more arbitrary than just the arbitrary criteria of one evaluator.
So the concern over rolling takeoff etc. worthless. The "waiver holder" equivalent of adding digits after a decimal place and thinking the answer is more precise (hint, it isn't)
#120
My Feedback: (29)
ul
The way I see it is that you have the freedom to fly a jet anywhere you want without a waiver or membership in anything except an AMA chartered club field. The club are the tenants of the property and have the legal right to have you pay membership and follow their rules if you choose to use the facility. Same applies to anyone who wants to play a round of golf at a country club or go shooing at a private club. It's your choice to have fewer privileges, nothing is being forced upon you.
#121
Meanwhile, the competition for airspace moves ahead...
While this discussion continues, it may be irrelevant before long.
The ink's not even dry on the comments on the ANPRM for Safe and Secure Operations of Small Unmanned Aircraft, and within days the Secretary of Transportation announces the first commercial drone package delivery in the US. And not in some obscure and relatively unpopulated region, right in the mid-Atlantic area! I can't imagine that Amazon, Google, and countless others are far behind. There not only might be others competing for the low altitude airspace, it's now a reality.
https://www.faa.gov/news/press_releases/news_story.cfm?newsId=23554
I couldn't help but notice that AMA (most certainly not JPO) are among the six major groups with whom the FAA met (CNN, MLB & Sports Group, Small UAV Coalition, Commercial Drone Alliance, Airmap, and AirXOS). With those groups PLUS ALPA, A4A, Ag Aircraft Flyers, etc. weighing in on need for control of the lower airspace, it's not "if", just "when."
Enjoy the "waiver" thing while it lasts.
#122
My Feedback: (54)
Thoughts?
Bob
Thoughts?
Bob
I would also add flaps, and like the idea of retracts, but really isn’t necessary. I do agree that it shouldn’t be on a hand launch under 7.5#. Some say that they wouldn’t sign a guy off with a Shokjet. I have signed a guy off with a Shokjet. He did very well and sold the jet after a hundred flights. It was what he could afford and fly with his skill level. He did buy a Panther F9, flew it a couple times in the air and about lost it on his last flight. I bought it for a “friends price “ . But fear of loosing the jet, aware of his inabilities, and possible money lost helped make the decision of the complexity of the next jet. Most of the time, a guy’s talent and budget will help control how long a guy flies jets. Because of the fear of loosing the investment, I think that it helps to limit carelessness and taking risks. If a guy doesn’t have the talent, or is loosing his talent as he ages, he will wreck, probably on landings. Most of the time, I see that these guys quit flying jets, because of budget. So, the system does eliminate those that are dangerous or becoming dangerous.
Sorry, got to far off of the Shokjet. But, it is a minimalistic Jet. So, wouldn’t go less.
If a guy has money, then no matter how many times he wrecks, he just orders a new one on the way home. We have a guy at our field. So, no matter what he flies, you can’t prevent money and stupidity from being dangerous. After all, achieving the waiver is a determination of Competency and risk. I would like to think that other CD’s like to protect their own reputation, and thus don’t sign off a guy until he is ready.
I also agree with the argument of why you can fly a Bandit with an EVF, go way over 200, and don’t need a waiver. Yet put a turbine in the same jet, and limited to 200, must have a waiver, and a spotter. Not sure if the electric jet requires a spotter.
I don’t think that we should limit a person from getting a waiver on what he can afford.
#123
That's pretty easy. AMA turbine waivers are only issued to AMA members.
AAA towing is only provided to AAA members.
AARP discounts are only given to AARP members.
So he would need to join the AMA, follow the waiver process and possibly join the club he's flying at.
I have to agree with Franklin, your comparisons are flawed as:
I can get towing coverage from any insurance carrier, not just AAA
I can get discounts due to being former military, through my job, and from other sources, not just through AARP
the AMA has a monopoly on turbine waivers, as stated above by BH, so there is no other source to obtain one. Seems to me that the AMA has set itself up for litigation if someone really wanted to push the issue in court
#124
+1
The key point in the above, FROM A POLICY MAKING AND IMPLEMENTATION PERSPECTIVE, is the very first answer that comes to mind when you ask "Why does the waiver program care if individuals like those described above crash?"
If the answer is money. That tells me the waiver program about preservation of a "beautiful plane," preventing needless wasting of money, etc. But from a policy making perspective, these concerns aren't really that consequential from an organizaional standpoint. The program should be designed accordingly, and in context of discussion, would point to allowing one to qualify on any turbine and then move on to flying any other turbine.
If the answer is 'because they might be a risk to others," then don't look now, but from a FROM A POLICY MAKING AND IMPLEMENTATION PERSPECTIVE, you're creating a reason for a better defined qualification process, one that is built with the understanding that the flying a larger turbine SAFELY requires demonstration of skills that cannot be done with smaller turbines. This would point to a process does not allow a 12lb or less qualification.
However, that now means that FROM A POLICY MAKING AND IMPLEMENTATION PERSPECTIVE, your issue is where to draw the line? Or is it even one line and not two? And guess what, assuming it's one line, then you've just made it difficult for those you want to join the community by making them buy something they don't want - just to get the waiver. Worse yet, from a growth of the hobby perspective, they may not buy at all and say "forget it." If the communnity is ok losing those folks, then stop worrying about it. Hit them with the same vigor that we see people use the "non-waiver holder" (in various forms) here on these pages, something like "Sorry buddy, if you can't afford a bigger jet, then come back when you can."
But I suspect that's not what the community wants. So now you're back to the base problem, assuming it is a safety issue, and assuming you want to lower the barrier to entry. So again, FROM A POLICY MAKING AND IMPLEMENTATION PERSPECTIVE, maybe it makes sense to draw more than one line? Basic waiver with a 12lb etc. jet. Then some sort of additional demonstration of skills before cleared to fly larger jet w/o supervision. Is that a separate waiver? Or merely a couple check flights observed by a CD? Or a couple check flights observed by other waiver holders who themselves are signed off to fly larger stuff? But based on the comments above, it sounds to me, FROM A POLICY MAKING AND IMPLEMENTATION PERSPECTIVE, that there needs to be some intermediate step.
Of course, as stated above, this only matters if the organization sees this as a safety issue and not a preventing waste of money. But alas, I'm not a waiver holder, so since I don't have any knowledge of flying these things - as stated by the head of JPO himself - then I can't possibly know anything about POLICY MAKING AND IMPLEMENTATION, or risk management, or qualification programs, or training programs, or any number of topics part of this problem that DO NOT require hands on experience flying these things to still be valid points.
