Savox servo whine
Reply
Old 04-23-2019, 01:09 PM
DrScoles
My Feedback: (18)
DrScoles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Savox servo whine
I purchased a jet that has all Savox 500oz titanium geared digital servos. Setting up the control surfaces with a servo load amp meter, even at .15 amp, they make a ton of noise. My futaba servos are silent at rest. This plane is big, has double servos on elevator and leading edge slats. I've got them mechanically set perfectly with servo matching in the powerbox. Still just the weight of the elevator or the flap at rest makes them buzz. I've got the load under .15 everywhere at full travel, just bugs me to hear the sound.
What is the acceptable load at rest for our servos? I'm new to this amp meter, its bad ass!
DrScoles is offline
Old 04-23-2019, 01:14 PM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get used to it, they make a racket.
BarracudaHockey is online now
Old 04-23-2019, 01:31 PM
Len Todd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Savox servos are noisy, period. But you get used to it. At rest I like to see < .04 amps max to hold up a heavy surface (e.g Giant Aile with twin ganged servo). If the servos are under load, you could easily see a couple amps, depending on the sensitivity of the meter and duration of the load. That's exactly why I use Powerbox. 10 servos at 4 amps each is 40 amps. I am not comfortable with that degree of current on a typical Rxer buss. Digital servos are relatively power hungry. But Digital servos move a lot faster than analog and the loads can be in parallel versus analog servo loads are in series. Consequently loads on power systems with digital servos can stack up quickly. But back to your questions: Savox servos are just noisy!
Len Todd is offline
Old 04-23-2019, 02:55 PM
DrScoles
My Feedback: (18)
DrScoles's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, makes me feel better. This plane is set up with two lines of powerbus going down each side into Royal SRS with two 5000mah powerbox lipo's. Four powerbus adapters each with three servos on each one and they can handle 20amps each... Just have to get used to the damn noise!
DrScoles is offline
Old 04-23-2019, 03:33 PM
Dieselman1220
My Feedback: (25)
Dieselman1220's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup they are just noisy, fantastic servos though.
Ive exclusively used 1256 and 1258s on many jets and have yet to be disappointed.
Dieselman1220 is offline
Old 04-30-2019, 02:24 AM
jjantti
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Savox servos seem to humm a lot but do work great other vise. I have been using them for years now. Just will not buy 1258 again. They seem to have a serie with weak motor bushings or something. I have scrapped few of them now because of squeeking on rapid movements. Does work OK but motor bearing seems to be worn after few tens of flights.
/Jyri
jjantti is offline
