Reload this Page >
Bypass Question - Use Heatshield ?
Old 07-05-2019, 01:03 PM
BalsaBob
My Feedback: (24)
Default Bypass Question - Use Heatshield ?
Hello All, I’m using a carbon fiber bypass and am wondering if it is common practice to coat/paint the rear half of it with BVM Heatshield ? I’m using just the bottom half (to add some heat protection to the gear and other components .... and don’t need the extra thrust that a fully enclosed bypass might provide).
Thanks. Bob
Old 07-05-2019, 01:56 PM
Harley Condra
It is a very good idea to use Heatshield as a method to prevent heat damage to bypass tube. The carbon fiber is not easily affected by the temperature, but the resin is.
Apply three coats to the inside aft end, top and bottom, allowing some time between coats. I usually coat the last 4 or 5 inches of the tube and cover.
Think of it as a safety measure for an expensive jet. My jet is worth far more to me than the expense and labor of applying the Heatshield.
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
I have used the product once before on one jet, but haven’t for at least the last six jets.
Old 07-05-2019, 02:57 PM
RC_MAN
I use it all the time, great product.
Springbok Flyer
Springbok Flyer's Avatar
I only install with full bypass in all my jets since 1997. I have 9 at the moment and have never used heatshield on the pipes or bypasses. However, I have at times added heatshield to the inside of the fuselage in the tail section.
Old 07-05-2019, 03:17 PM
BalsaBob
My Feedback: (24)
Thank you all for the feedback. Since I have some Heatshield on hand, I will use it.
Bob
Old 07-05-2019, 05:10 PM
joeflyer
My Feedback: (48)
I've used just the bottom half bypass on a couple of my jets. Since I was concerned about radiant heat from the tailcone after shutdown, I added aluminum tape to the rear several inches and that's worked out fine.
Old 07-07-2019, 10:52 PM
Doug Cronkhite
My Feedback: (34)
It definitely works. It's it 'necessary' ? Probably not in some cases, but like Harley said.. You're pending thousands of dollars on your airplane. What's a couple hours of your time to help improve things?
Old 07-07-2019, 11:52 PM
Ceeray
Heatshield paint is very heavy. Consider also that when applying..
Old 07-08-2019, 11:02 AM
Auburn02
Auburn02's Avatar
You'll have to decide if you want to paint 4" of bypass with heatshield even if it means leaving an ounce of fuel on the ground to meet max takeoff weight limitations.
Old 07-08-2019, 12:02 PM
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Don’t forget second stage climb if twin engine!
I think that it was mandatory to use when hot starts were more prevalent in the days of scuba tank air starts, propane, and glow plugs. IMHO...I believe that kero start is a more consistent and a cooler start. If you’re using a full bypass, I use a air bed pump to help with the cool down after the flight. In flight, it isn’t an issue because of being surrounded with fast moving air for cooling. If you are hovering the jet, then it probably needs used somewhere. I also program the engine ECU to cool down to 80 C. This way there is less radiant heat.
