Let's See Your On-Board Layouts!
My Feedback: (52)
Hey guys,
I'm at the point of laying out my on-board setup on my new Futura 2.5, and thought it would be informative to see some of my jet-brethren layouts in their jets. I'm using a Jeti CB200 for guidance and Rhino 200SE for power. Everyone has their own way of doing things and I'd love to see what some of your have come up with. Let's see those pics!! Thanks. Mark.
My Feedback: (53)
My First Ventrix
My SAB Havok
My T-1
my Mini T-1
My Second Ventrix
My Boomerang XL, Playing with the layout
My Boomerang XL.....once happy I drill all the holes/slots....then a few light coat of dilute Finishing epoxy...with some sanding in between then paint...
My Feedback: (29)
Futura
I wanted to do the simplest possible set-up, minimum possible equipment to ensure low weight, reliability, ease of access and repair, while having a gyro as well, I also switched to electron landing gear to do away with valves, servos and air lines/fittings. Went overkill, ended up putting weight in the nose...
receiver batteries are located on the nose tray
I keep bugging Edgar (his set-up is a few posts above) about his having excess weight and complexity, it’s a sport model, should be kept in “charge, fuel and go” ready status, but that’s just me...
My Feedback: (20)
I mostly use Lite Ply 1/8” poplar plywood mostly because it’s easy to work with, cheap, and I have a bunch of it in the shop. Easy to modify if changes needed. Probably lighter stuff out there.
Gary
Gary
My Feedback: (54)
My Ultra Lightning. Just finished the refurb this year.
Lower level has a PB Mercury SRS, 3- Electronic Air Valves for gear and doors, 1- Electronic Brake Valve
Fuel Panel- Festo is fill valve, plugged secured and goes through the bottom red shut off valve. The middle valve is for the engine with hose showing for fuel flow and hopefully lack of air.
My Feedback: (50)
old but good ideas
Hey guys,
