Reload this Page >
Turbine incidence on turbinator? with Jetcat 80 SE
Old 09-12-2019, 11:58 AM
jmm
My Feedback: (74)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Turbine incidence on turbinator? with Jetcat 80 SE
Turbinator go up with throttle?
jmm is offline
Old 09-12-2019, 03:00 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Turbinator's engine mount was designed around a 13 lbs thrust engine, if a bigger engine is use ( they were used ) then, that extra thrust will make it climb on level passes at full speed, the engine's front has to come up, if it is climbing slightly, use two washers each side under the front mounting screws, now the back of the engine is pointing down more than before, go fly it.
CARS II is online now
Old 09-12-2019, 06:10 PM
dwhorn
My Feedback: (28)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Run a Jet Munt 80 in mine with 18 degrees downthrust. No climbing and no trim issues at low
or high speed flight. Flies great with this set up.
dwhorn is offline
Old 09-12-2019, 07:17 PM
jmm
My Feedback: (74)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jmm is offline
Old 09-13-2019, 12:29 PM
rhklenke
My Feedback: (24)
rhklenke's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah, for more down thrust to combat climbing at full power, you need washers under the REAR mounting screws to lower the REAR of the engine as the engine in the Turbinator is mounted inverted...
Bob
rhklenke is offline
Old 09-13-2019, 08:08 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Then we are on agreement.
"to lower the REAR of the engine"
"now the back of the engine is pointing down more than before"
I'm glad we think the same way
Old 09-15-2019, 09:59 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is from the BVM KingCat manual.
I had an itch and I finally gave it some thought, Bob is correct, the engine is mounted on the underside of the rails.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
