JETI Assist Orientation
I installed a JETI Assist 10A last night with the receiver's label facing up and the arrow pointing to the right side of the plane. It has the latest firmware (V1.12) loaded using JETI Studio. My DS16 is running 4.28 firmware which is also the latest version. When I got to the point in the configuration wizard where you specify the receiver's orientation in the model, I was not able to find 270 degrees. 270 was supposedly added as an orientation option in receiver firmware V1.10. So, I loaded V1.10 using JETI Studio and that didn't help. I then downloaded the latest firmware update directly from the JETI Model website (V1.10 is shown as the latest at JETI Model while JETI Studio shows V1.12 as the latest) and loaded it directly without using JETI Studio. No change. If I have to remove and reorient the receiver, I'll have to either re-wire the plane or make servo extensions for all cabling. Has anyone else come across this problem?
Mike
Mike
Found the problem. I come from the days of non-programmable radios and occasionally struggle with modern electronics. While I had the latest firmware loaded in the transmitter and receiver, I didn't have the latest "Devices" folder in the transmitter. Once I did that, I was able to find and select the needed 270 degree orientation for the receiver.
Mike
Mike
