New PC-21 XXL 4m fuselage
New PC-21 XXL 3.4m fuselage
Just saw this on the JMB website
https://kingtechturbine.lu/JMB-JETS-PC21-XXL_1
Our new PC-21 XXL
Big and light, full composite Airex / Carbon
Scale
The PC-21 comes in ARF + with already installed components such as electric scale chassis, lighting, tanks, and painted in the desired design.
or as PNP everything as in ARF + and additionally all servos in HV / ALU
Specifications
Length: 3395mm
Wingspan: 2735mm
Weight dry depending on the gear 19.8kg
For K60TP or K100TP
Full composite versus their original somewhat smaller PC-21 which was built up condtruction
I really like the looks of this plane but have no way of transporting it!
I’ll have to stick with their original since the fuse splits in 2
Our new PC-21 XXL
Scale
Specifications
Length: 3395mm
Wingspan: 2735mm
For K60TP or K100TP
It says it’s 3395mm long, that’s not 4m?
I don’t want to put a dampener on this thread but I think it’s the same manufacturer who produce a small Mirage I test flew for a friend last weekend. Let’s just say the construction is shocking, control horns glued into the foam skin, no wooden blocks under, poor/no glue on internal structure what I saw smacks of another FEJ set up.
Dave
Dave
Dave
Dave
The original JMB PC21 was from XtremeARF in China as I found it on a google search a couple years back
I don’t know if the same company produces this one
You’d have to ask JeanMarc
I just finished my PC21 Xxl in Ecuador camouflage finish. I changed all controllers and replaced all led's by Unilight led's as well as its light controller, the gear controller was changed to a ER50 from Elektron. I did not change the gear electric motors as they seem to work with the Elektron controller. I left the HV servos in (initially want to replace them as I had ordered a complete new set , but after some mail exchanges I will stay on the original delivery ones) End result is 23,5 Kg on the scales (no fuel) KTP 100 in front with scale prop. I still have to figer out the exact position of the CG as two different figures are given in the notice, but it should be close to the centre wing carbon tube. (+/- 30% of the wing cord at wing root.) The plane is very well executed and glue fills are all correct.
