Electronic Retract Valve by Mini Hobby
Has anyone used one of these instead of a Server and Valve?
http://www.minihobby.com/electronics/mhvalve.htm
IL
I have not used the MiniHobby valve, but I did check it out at last year's Superman.
I've only used the valves from Bob Wilcox at JetCat...
http://www.jetcatusa.com/acces.htm - you need to scroll down a little
FYI, the JetCat valve is a lot lighter than the MiniHobby one.
In my roo, I have one for my spring air retracts & another in proportional mode for my BVM brakes - both systems work as advertised.
DIsaacks and Easytiger,
If you go to the goldenwest site you can buy a single valve which is used for either brakes or a spring air type of gear which is 65.00 or you can buy the double valve which looks likes two singles crammed together and this is used for air up/air down gear. I have both types in my bobcat and they work flawlessly and are a joy to set up. The big plus is that they don't leak and you don't have to change out O-Rings. I think the solenoid in them are rated at over 15,000 hours of constant operation so for our purposes they will last for years. Also, they can withstand up to 200lbs of pressure so they can be used for larger jets as well. I have attached a pictures of the ones I have in my bobcat the one on the left is my dual valve used for retracts and the the one on the right is a single and is used for brakes.
Patrick
Patrick
NY
My Feedback: (60)
IL
Hi,
I used the Minihobbies Retract and Brake valves in my Roo.
Read the instructions on both units, they need to be initialized !
They work very nicely. I wire tied them to the header tank tray.
John
John
IL
Originally posted by bkf
Hey Dude: How did you keep the air usage down? I just tried running in Pro. mode and it did burn up a bunch of air.
You'll dump too much air without a restrictor(s) in the drain line.
I use Robart #189 restrictors - they're made for 1/16 ID lines & come 4 in a pkg.
In my Roo with BVM brakes, 1 restrictor in the drain line was not enough. I changed to 3 in series & it works perfect.
I use a Robart #191 (30c.i.) tank that supplies BOTH my retracts & brakes & I have absolutely no problems.
NY
The JetCat/Jet-Tronics instructions clearly state "Drain in PWM Mode - Restrictor Required"
You should check out following web page.
He got all the electronic valves and components around
turbines and gears. Specially comparing the dollar to euro.
i thing its close to one by one.
Using the projet ecu once, i guess you will never switch back.
Also with his door sequencer or brake valves. If you got valves you can just purchase the electronic to operate the valves. http://www.projet-ecu.de/
NY
Originally posted by EASYTIGER
No way! The valves are only 17 euros? That's about seventeen bucks. That can't be right, can it?
17,50 euro i think is just for the electronic to operate the valve
complete with the valve is about 38 euro.
but you can get the valve also direct from festo and just use the electronic from projet
gerhard
gerhard
i thing the best way is just to contact thomas ernstberger
under following e mail adress. i thing you get all the info you need from him
[email protected]
gerhard
[email protected]
gerhard
NY
Originally posted by mach1
Are the JetCat valves truly proportional or do they do the "pulse"
thing like the mini-hobby valve?
W.G.Hunter
W.G.Hunter
