JPO Position Paper Regarding The New Turbine Regulations
My Feedback: (540)
RE: JPO Position Paper Regarding The New Turbine Regulations
200 MPH speed limit ???
How can it truely be done??? Gound speed or Indicated air speed or true airspeed ???
My jetcat and Mini hobbies speed limiters both use a pitot tube and static port, neither can compensate for headwind, tailwind or crosswind componet. And then there is calibration and certification of these devices. Who is responsible for that?
ORIGINAL: J_R
2. The argument of “mean time between failure” appears to be a poor use of logic.
Overall the proposed rules seem to correct the more erroneous theory present in the current rules but I'm not sure that I agree with the elimination of the ground school requirement as this seems to me to be the primary source of information to those just getting started in turbine powered modeling - at least it was the most informative part of the waiver acquisition process for me. A notarized signature from one of the witnesses is not going to be of much help to anyone.
The non-notarized signatures of two to three witnesses is not acceptable to the AMA? Notarized signatures and multiple witnesses are not even required to get a pilot certificate from the FAA. Who comes up with this nonsense? This is a hobby, is it not? What's next, turbine police?
I also don't follow the logic that says a single turbine installation must be limited to less thrust than a multi-turbine installation, regardless the engine out performance characteristics of a multi-turbine powered model. If I build a multi-turbine model (a 55 pound F-15 or F18 for example) and choose to power it with a single turbine blowing through a bifurcated pipe, why should I be penalized 5 pounds of thrust? I agree with a previous poster that the rule should simply state maximum allowable thrust regardless the number of turbines installed - then design the model for engine out performance accordingly if that is your design goal. And since thrust to weight ratio is being eliminated as inconsequential to limiting speed, FINALLY, why limit maximum allowable thrust to 50 pounds when the maximum allowable weight of a model is 55 pounds? Why any thrust limitation at all since a speed limitation is being specified?
Things that make you go, "hmmm".
ORIGINAL: F106A
Hi Reid,
What's next? Go to the AMA forum and look at the thread about random drug testing.
Jon
Hi Reid,
Jon
ARE YOU SERIOUS!?
"His wingman kept requesting permission to fire". "This stuff is gonna get outa hand and somebodies gonna get hurt"!
