Suggestion for the King Cat
Honoring Murphy's Law, I ran over the only puddle of water on the entire runway, on take off.
After landing I found out that I had water all over the electronics. Most likely the spining wet nose wheel (after retraction) causes some of that.
Here is a simple suggestion for avoiding it. (underside of the electronics plate is also blocked with 1/8" balsa under the gear wheel cut out)
Hope this helps
Jack
Hope this helps
Jack
ME
RE: Suggestion for the King Cat
Thanks Jack, that's a good suggestion. It's also very responsible of you to post it as a suggestion that will further enhance the safety of our models. I was thinking of doing something similar but making it removable.
Antony
Antony
