Yellow Aircraft F/A-18 Twin!
Reply
Old 04-02-2010, 11:36 AM
  #1651
SDCrashmaster
SDCrashmaster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Yellow Aircraft F/A-18 Twin!
Quote:
ORIGINAL: yeahbaby
Quote:
ORIGINAL: SDCrashmaster
It would be...if it had the splitter plates installed
haaa haaaa Paul, just imagine me at the 1 minute mark.
[youtube]http://www.youtube.com/watch?v=IOM2BtrdN_c[/youtube]
Funny stuff. Nice to see Farley again
ID:	1410096   Click image for larger version
ID:	1410097   Click image for larger version
ID:	1410098   Click image for larger version
SDCrashmaster is offline
Old 04-02-2010, 01:58 PM
  #1652
yeahbaby
yeahbaby's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
haaaaaaa who is that handsome Devil???? nice photo shop work i'll add 'em to my limited collection.
Hey Dennis
{{ I cannot thank everyone enough for all the info that I have used from this thread. I built a twin 120 powered F-18 for a fellow years ago and gathered info then, and now I am about to glue the fins on myown F-18 and was wondering if someone could please give me the distance between the top of the fins.
Thanks very much, Dennis. }}
if you set the fins at a 70 degree angle (double check the manual) you'll be all set. perhaps you can PM Shaun for measurements to be more precise. i'm going off memory
yeahbaby is offline
Old 04-02-2010, 02:42 PM
  #1653
wardie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is good info, Thanks. I bought this plane with damaged tailcones and no manual, I have the plans though.
Thanks again, Dennis.
wardie is offline
Old 04-02-2010, 08:12 PM
  #1654
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the 70* that buck mentions sounds about right to me as well...
invertmast is offline
Old 04-03-2010, 06:48 AM
  #1655
jkirkon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an electronic copy of the manual. If you want a copy, PM me.
Jeff
jkirkon is offline
Old 04-27-2011, 05:05 PM
  #1656
jetsflying
jetsflying's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have recently acquired a yellow f18 twin from a fellow rc member at a price i couldnt refuse. its the older green fuse version. Its never been flown but has been built for turbine installation. the only concerns that i have is that i have read some of the other threads(about the plane breaking apart in mid air) the bulk heads seem to be 1/4 inch plywood. i am in the process of making an extra 1/4 inch plywood to double up the bulkheads. Is that sufficient enough? Has anyone done any other modifications I should know about? Also, the pipe is already installed, the front of the pipe is 3 1/2 inch in diameter andin the exhaust nozel side is 2 1/2inch. I am planning of using a mamoth or a p200. Is that sufficient openings or do I have to replace the pipe? Also if anyone has a manual that can make a copy and send it to me, I will compensate you for it. Thank you in advance, chris.
jetsflying is offline
Old 04-27-2011, 06:43 PM
  #1657
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Chris, me again!
My understanding on the topic of the bulkheads after talking to Charles (the owner of yellow) is that he redesigned the bulkheads years ago to accommodate a jetcat 180. There is a new bulkhead kit that you can get off him if you like. Shaun Evans here on RCU can probably help you with that too. I think Charles also stocks the appropriate pipes (and they are very nicely made and packaged for shipping) but if not I am sure Tamjets would have what you need.
I have the kit and ARF version which I am yet to fit out but they are a great flying jet with the correct ground stance for smooth takeoffs.
Good luck!
Regards,
Craig.
Craig B. is offline
Old 04-27-2011, 06:54 PM
  #1658
jetsflying
jetsflying's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi graig how are you?.........the problem is that thebuilkheadsare already glued and i don't know if i can remouve them without dameging the fuse, also how can i put a new pipe wen the bulkhead is already glued
PS. HEY GRAIG I JUST GOT MY GYRO TODAY , WILL TRY TO INSTALL IT OVER THE WEEKAND
Old 04-27-2011, 07:04 PM
  #1659
Shaun Evans
Shaun Evans's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Why don't you post a couple of pics of the bulkheads, and I'll let you know whether you are good-to-go or not. Depending on the pipe and your bulkheads, you may be able to get your pipe in and out just fine. What pipe is it?
Shaun Evans is online now
Old 04-27-2011, 07:07 PM
  #1660
jetsflying
jetsflying's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i will post pics tommorow.......i have no idea what pipe is it......
Old 04-28-2011, 03:09 PM
  #1661
jetsflying
jetsflying's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here is the pics...
ID:	1600536   Click image for larger version
ID:	1600537   Click image for larger version
ID:	1600538   Click image for larger version
ID:	1600539   Click image for larger version
ID:	1600540   Click image for larger version
ID:	1600541   Click image for larger version
ID:	1600542   Click image for larger version
ID:	1600544   Click image for larger version
ID:	1600545   Click image for larger version
ID:	1600546   Click image for larger version
Old 04-28-2011, 03:15 PM
  #1662
jetsflying
jetsflying's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more
ID:	1600551   Click image for larger version
ID:	1600552   Click image for larger version
ID:	1600553   Click image for larger version
ID:	1600554   Click image for larger version
ID:	1600555   Click image for larger version
ID:	1600556   Click image for larger version
ID:	1600557   Click image for larger version
ID:	1600559   Click image for larger version
ID:	1600560   Click image for larger version
ID:	1600561   Click image for larger version
Old 04-28-2011, 04:24 PM
  #1663
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Weeellll....looks like you might have a couple of issues going on there. First, you definitely need to reinforce the front former. What you have there is correctly identified as the older, ducted-fan type bulkhead in there. Basically, the same one that was in the Hornet that blows up on the video. Like that bird, this one doesn't appear to have any glassing-in of the bulkheads (or even a glue bead from what I think I see in the pictures), though it's called for in the instructions. When I built one from the kit which had those bulkheads, I reinforced the bulkhead by doubling it with some carbon/aluminum composite. On the next one, I used 1/8" carbon plate. You would probably be ok with just 1/4" ply (Midwest or other good quality), but I would use Hysol and still glass those two main bulkheads in.
I'm really not sure what I'm looking at pipe-wise. It looks like there are stock DF exhaust tubes in there with a GEN 1 pipe of some sort inside it. You're definitely going to have to cut that bulkhead out to get the pipe out, but that's not going to be as big of a deal as it might seem. You would only need to draw an oval shape that is big enough to allow the widest part of a new pipe to pass through, then use a dremel to cut your hole. You definitely want to go with a modern pipe, though. Ours are very high quality, and rated to P-180.
It seems like you might have had more than one builder on this. You see that sometimes with a second (or third) hand build, where parts of the construction are obviously done by a competent craftsman; then other items are monkeyed to the point where you know that the person had no clue. Anyway, let me know if you need anything for it.
Old 04-28-2011, 04:50 PM
  #1664
jetsflying
jetsflying's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok ....great i will be call soon for and order, i just need a little time to put a list together, also cylinders for the doors and the speed break.....now a few more questions
the wings and stabs look and feel very strong, but i dont know what is in side?
do you sell builk heads from the new generation jets?
if i cut the builk head for the pipe then what, just double it up again?
do i need to reinforce any other area with carbon cloth?
do you think maybe i shoud cut the builk heads out comletely out and just install newer stronger ones
THANK YOU CHRIS
Old 04-28-2011, 05:18 PM
  #1665
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jetsflying
THANK YOU CHRIS
If it was me. I would scrap the bulkheads inside the fuselage and replace them with the newer style ones. I would also replace the wings with the new carbon reinforced wings.
Old 04-29-2011, 09:31 AM
  #1666
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thomas,
Looks from the pics like he already has the newer wings. If you look inside the servo pockets, you can see the carbon cloth.
Chris,
I don't know that it would be worth it to redo all of the internals. I think you just need to double up the front former, and you need not worry about the rear former, even after you cut it for the pipe. As long as the spar receivers are properly attached, there's plenty of meat there to render it safe.
Old 04-29-2011, 06:07 PM
  #1667
jetsflying
jetsflying's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what size fiberglass cloth you use to cover the wings?
Old 04-30-2011, 08:06 AM
  #1668
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I use 2-ounce.
Old 02-08-2012, 06:21 AM
  #1669
camacho
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi.
I just got the last F-18c Twin (single engine) according to Shaun and Charles and I would loke to get it as scale as possible.
Where canI buy this very scale looking Landing gear for my plane?
Thank you, Luis Camacho.
camacho is offline
Old 02-08-2012, 08:37 AM
  #1670
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Luis,
Yep, you have the Last of the Mohicans. Have you unpacked it? What do you think?
Old 02-08-2012, 09:28 AM
  #1671
TED ANTON
TED ANTON's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yellow's not producing the twin F18 kit anymore ?
TED ANTON is offline
Old 02-08-2012, 09:42 AM
  #1672
socshooter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shaun,
Question, do you check or reply to your business emails? In the past month I have sent you multiple emails requesting parts information for the twin F-18 to no avail. Is this the only way to communicate with Y/A?
Regards,
J
socshooter is offline
Old 02-08-2012, 09:44 AM
  #1673
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
What email are you sending them to? What address are you sending them from?
Old 02-08-2012, 09:46 AM
  #1674
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
He's got the last ARF. The kits are available.
  #1675
grbaker
grbaker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Excellent!!
grbaker is online now
Reply
Display Modes
