P-120 or 160 in the new Super Vipers?
FL
By the way, I forgot to mention in my Tam's getting back tomorrow post just now, would a P-160 be too much power in the new Super Vipers, or should one just stick with the 120? What do you guys think? Gary.
My Feedback: (47)
RE: P-120 or 160 in the new Super Vipers?
It's the same airframe, aerodynamically...It does not need a P160, my Mark 2 flew vertically with a nearly full bag of fuel and just over 1/2 throttle on an older P120. If you do use a 160, I'd dial the max thrust down to 28 lbs or less, it's a clean plane and you can easily overspeed it.
Just my $.02.
Barry
Just my $.02.
Barry
As per the new modifications made to the Viper, its structures is capable to handle the power of a P-160, including the G's w/o any problem.-
Anyway, I flew mine with a P-120, and see no point in going faster, unless your visual range are long enough to increase your flying zone....or use binoculars
At the end is a matter of personal taste....
Regards,
Miguel
Regards,
Miguel
p-160...speed up the situation my friend........
ORIGINAL: Miguel Santana
Regards,
Miguel
Regards,
Miguel
