SUPER REAPER MAIDEN FLIGHT SOON NEED ADVISES
#151
RE: SUPER REAPER MAIDEN FLIGHT SOON NEED ADVISES
ORIGINAL: Wayne22
Cool! I didn't know there were any other TJT powered Reapers out there!!! I have a couple of friends in Vancouver who know these engines inside out. I answered your PM about the landing gear...
Here is what happened to the stock landing gear after hitting the gopher hole on take off...
Wayne 22 This is my gear setup . Sierra precision on the nose ....too expensive when needs repair . Intairco wheels on the mains....dig into the grass too narrow and hard. The main gear is too low , I tried to PM this pic but file was too big .I also have a TJT 3000 in my Reaper . Where do you get your TJT 3000 serviced ?
You seem to have a hybrid wheel.....looks like a foam wheel with brakes spliced in . I looked on the DuBro website for the fiberglass gear but did not see a good replacement ........do you recall the mod no. or size . I really like the Snowbird scheme . Thinking about it I think my aluminum gear came from Houston Hobbies .
#152
ORIGINAL: siddus74
Mike, yeah the amperage requires some thought . . . the Gemini can supply 10amps which I feel should be adequate . . my chosen servos are listed below
Futaba S3010 Elevator x1
Futaba S9202 Ailerons x2
Futaba S3001 Rudders x2
TPro S5010MG Flap x1
I dont think they wil top 10 amps do you? I may wire some thing up to tray and rest potential current draw . . . I stumbled accross some spectrum documentation that gave example of a 33% Sukhoi with 7 x JR8611s installed (that set up drew a maximum of 6.9amps) see the picture and the attachment for further details . . . quite interesting - what do you think?
ORIGINAL: BaldEagel
As long as you do not use high end Digital servo's that Powerbox will be OK, JR8711's can pull 4.6Amps each so the limit would be the powerbox if you went that way, you would also have the problem of the possible low voltage drop out of the Spektrum Rx, you pays your monies and take's your..............etc:
Mike
#153
AB, CANADA
I had some trouble with my TJT 3000......took seven months to get a working ECU.......that was about 4 years ago.......I am a little reluctant to send my TJT to Australia for service . Do they still make this engine ?
Those are the unibrakes that you see in the picture - bad idea, they didn't work. Those were replaced with proper jet wheels and brakes. I looked at the Dubro strut today, and it is a bit smaller than the Klett unit... However with the proliferation of giant scale aerobatic planes there is lots of aluminum or carbon fiber landing gear that could be adapted...
Here is a pic of it on a landing approach with its new wheels...
#154
ORIGINAL: alasdair
I can't remember what servos I used in the Boomerang. Certainly not digital, may have been high torque Hitec 625 or TP 5010, I just fit and forget, and sold it 130 flights later.
For the Spektrum radio (fitted in my JayTee) I started with a 5 cell AA high capacity battery but soon switched to a 5 cell 1400 mAh high current battery (I think the cells are 2/3 subC or similar) when I learned about 'brownout'. The high capacity NiMH AA cells have a high internal resistance and the voltage sags under load. With ''quickconnect'' receiver and a fade counter if possible it is not a problem.
As per email > I have some Futaba S9202 and S3010 but they all seem to show play when fitted due the larger horn length. Bizarrely I have some Tower Pro SG5010 with a massive 6K of toque @ 6v and they show no play at all! Can I really fit cheap Chinese Tower pro servos to a turbine? I was going to put a battery baker in any case, I have 3 xS9252 servos as well but they can only run @ 4.8v which is a real shame as there are fantastic servos of great specs.
I am very undecided . . .
Any adice wold be great.
Scott.
#155
Scott
Keep asking eventually you get the answer you want.
If you are going to use a battery backer, why not get one that regulates the voltage too 5volts as well then you can use the 9202's, I think I used to use those in my Helio's in the dim distant past, when assesing play have the servo's attached to the Rx and switched on, its supprising how much play disapears when the power is going through. If you do decied to go with something else, have a look at the Hitec 5625 & 5645 MG's or the equivilant in Hitec, they keep updating them, they are fully programmable from a cheap little unit that plugs into a PC, even a fail safe position can be memorized into the individual servo's.
Mike
Mike
#156
Wayne22, Hi,
I like the pic you posted here, do you have more of your Reaper to share please ???
siddus74, Hi,
Futaba servos, and 4.8volts,
I have a set of 9255, top heli servos as listed by futaba, came with a 12fg set i bought last year, now i to was worried about the voltage, as im going to run them in my new PST Reaction, on a Powerbox Gemini, at 5.9volts... Have been told that its not a problem, by Powerbox, and Intairco in Australia... Also going to use 9252, and 9202 servos in the same setup...
I think one point to mention, is the voltage thru the Powerbox set, doesnt exceed 6volts, where as a 6volt pack, off charge will got to near 7volts...
Hope this helps you...
Cheers Jeremy.
siddus74, Hi,
Cheers Jeremy.
#157
ORIGINAL: BaldEagel
Scott
Mike
Scott
Mike
I think I am going to run with the 3 x S9252's on the ailerons and the elevator and use and a Fromeco Sahara Regulator set to 5.1v, the heli boys use these bad boys all the time and they dont have any issues with them . . . I battery backer would be nice but I dont think essential. The BMFA regulations say that the backer is a personal thing. If it was an 8K scale number with a 160 jet cat then yeah, but the entire model was only a grand . . .
The regulator and battery will cost about £90 this protects the servos and protects against the spektrum brown out issues . . .
The guy from Real Raptors say they have excellent history and never come back.
As you say you pay your money and take your chance, putting £8 servos on the critical controls is a no no for me.
Thanks again,
Scott.
#158
siddus74
Great, good you found a solution your happy with, i just had a look at the Sahara reg, yes looks good, and sounds like a good match with what your wanting to run...
BaldEagel,
How have you found the Reaper to build/assemble ???
How big is the box its shipped in ???
I to am looking for a cheeper, Hack jet to build, that can run a range of engine sizes....
Cheers Jeremy.
BaldEagel,
Cheers Jeremy.
#159
Sods law, you order what you think is the best solution then you find a cheaper equivalent with a battery backer!
[link=http://www.fast-lad.co.uk/store/product_info.php?products_id=3564]FLIGHTTECH 8A LINEAR VOLT REGULATOR [/link]
Has anybody used this item? My mate had one in a 50cc yak for about a year and I never new! lol
Siddus74
Siddus74
#160
ORIGINAL: Sonicwings
siddus74
BaldEagel,
Cheers Jeremy.
siddus74
BaldEagel,
Cheers Jeremy.
The build is easy if you have built before, ply fus sides and internal formers and foam wings pre-covered with thin ply (can't spell venier) , mine came in three seperate boxes, but I did order other stuff with it, the wings are the biggest box about 1.2M sq, with fixed gear it makes a good hack, I am looking at just a couple of wheels sticking out of the fus with tip skids to make it even less trouble, maybe a mechanical brake on the front wheel only, just push the nose down once on the ground to slow up or to take off lift the nose, the width of the rear turbine deck will take a motor up too 112mm wide, perhaps even a little wider, all accords on the width of the mount.
Sorry I can't be more specific on the box's, send Mick Reeves and e-mail and ask, he or his son are very helpful, they also sell pleated paper clunk filters which if you install them in the main tank you can do away with the UAT.
Mike
#161
Let's be honest about these things, the voltage regulators and battery backers are only as good as the battery they are using, no regulator can continue to supply power to the Rx and servo's if the battery has fallen below the power requirements of the system, I know its telling granma how to suck eggs, but if you have a decent battery in the first place you don't need the regulators, have two batteries and you don't need the battery backer, none of these things will save an aircraft if a servo short's out or both batteries go bad, but in over 30 years of Rc flying I have never had that happen in the air, I have had it happen but on the ground, maintenance is everthing.
Now I think about it I did have one throttle servo stick at WOT in the air with the help of two other flyers we flew it around until the tank emptied and then landed it, now if that had been an aileron servo, but then I would not have put that type or size of servo on a control surface.
If you rearly want to push the boat out and have something which will isolate a servo which shorts out, then you are talking lots of cash for a PowerBox system, and if you want to check on what is happening in your airframe whilst its flying you are talking about the Weattronics gear, but at about £800 for a 12 channel Rx in my mind that is silly, unless you have a Mibo A10 or equivilant.
Mike
Mike
#162
AB, CANADA
Wayne22, Hi,
#163
ORIGINAL: BaldEagel
. . .but if you have a decent battery in the first place you don't need the regulators, have two batteries and you don't need the battery backer, none of these things will save an aircraft if a servo short's out or both batteries go bad, but in over 30 years of Rc flying I have never had that happen in the air, I have had it happen but on the ground, maintenance is everthing.
Mike
Mike
I was talking to a young mate of mine thats not long been at work and has very little cash, he's a great pilot and I would let him fly anything of mine including the jets - the point he made was that if it was his he would have little choice but but to run with the TP servos and would just run with a really high quality 4.8V / 6.0V subc Nicad / Nim saying "I'm sure that would be fine" - thing is deep down I know this to be true, how often do have we put a backer and reg in a £700 chopper and or a larger pattern model? Next to never I bet . . .
I am the worst offender for listening to other people and throwing money at an install thats really OTT, half of it I bet is scaremongering and the fact the the primary installation was crap, I bet only a minute percentage of failure as due to equipment.
As you said - the ground checks and maintenance are the key and always provail and the quality of the actual installation first off as well I feel . . .
Scott.
#164
Scott
Your right of course, but have a look at the new Enerloop Nimh's they do not give a false Delta peak and therefore do not cut off charging early, worth considering.
Wayne 22
The Fin and Rudder on the latest versions of the Reaper have been changed and I can't see them suffering with flutter looking at how they are put together now.
Mike
Wayne 22
Mike
#165
AB, CANADA
Mike
Mike
#166
Wayne,
You've seen my Reaper. It has two aluminum rails that bolt the Rudders to the Fuselage. You'd have to tear the side of the plane off to remove a rudder. The newer set-up is really strong.
The weakest link I find is the darn nose wheel. I have been fiddling for awhile to get a setup that doesn't goof up. The issue is that the plane uses a Spring air or Robart retract. A standard Robart strut does down to the wheel. Pull/pull cables are used for steering. What happens, the front strut pin bends slightly with each take-off and landing. The wheel then cants back. This loosen the cables. Then, the next flight the cable are slack and ta-da...no steering. The plane goes straight on landing. Great if your perfectly aligned, bad if if off a bit. Twice, I have skidded off the runway due to this loss of steering. A real bummer. I still haven't lick this bug out the CM special.....
Dave
Dave
#168
AB, CANADA
#169
Wayne,
Truen....but using an aluminum angle piece to secure the rudders would work on the wood or composite version that I have. Probably even better on the wood version. At least there is some meat to the fuselage frather than just some glass and balsa....
Dave
Dave
#171
ORIGINAL: ramboman
Hello...
Something new ?
I just got mine... to be powered withan EDF...
Hello...
Something new ?
Hmmm.....EDF...Mine has a JJ1400 and flies OK...nothing specular....you'd need a hell of a EDF setup to keep up with a turbine. This huge delta losses speed when you pull Gs faster than a working girl loses her knickckers when meeting a ship that has been at sea for a year!!!! You really need reserve power to add as you lose speed in hogher G manuevers. Not needed for modest straight line flying.
DW_Crash.
#173
All mowing canards
Hi!
I have just startes building my Super Reaper. I would like to have all mowing canards and need som tips how to make that happen! Carbon fibre rod and bearings? And where you have the rotationpoint on the canard. Sorry for bad english..
Svenn
Svenn
