Throttle servo slow with ZAP WC2
I'm sure I've seen this thread before somewhere but can't find it.
Is this possible?
I can put a servo delay in when condition switching but I can't find how to put a simple delay on the throttle (to simulate throttle lag on my propjets).
Please help
Is this possible?
Please help
RE: Throttle servo slow with ZAP WC2
Go into the ATV menu, press NXT and put in your percentage onto channel 3 (or whatever channel your throttle is on) 98% gives around 4-5 seconds IIRC.
CO
ORIGINAL: Andy_S_T
The thing you need to practice is power on approaches, get the airplane in a nose up high drag config... one that requires power on the approach to hold altitude! Learn to control airspeed with pitch angle and altitude with the power setting. Dragging a turbine bird in with power at about 1/3 throttle insures touchdown on not before the runway threshold. Now as long as the aircrafts airspeed is relatively slow, just reduce power, continue the flair and touchdown... another great help on shorter runways is pre-setting the wheel brakes then roll-out is straight and short.
Lee
ORIGINAL: Silver182
That's it.... but remember that will only 1/2 way simulate turbine thrust lag...good on the throttle up, but not for throttle shutdown... turbines reduce power very quickly, good thing that part is really necessary!
ORIGINAL: Andy_S_T
Don't ask me how to do it, since Futaba's crappy programming interface drives me nuts... but I'm 99% sure it can be done.
My Feedback: (60)
Once my sinkrate on my Eurofighter was so great that I ended up toughing wheels down with the tubine running at full power! As soon as the wheels touched I chopped the throttle and I was on deck without a worry.
Landing these fire breathing monsters is the most fun I have in this hobby That and all my fans [8D]
ORIGINAL: seanreit
Oh ... you mean ducted fans, right ? Whew. For a minute there you had me convinced that the world had gone nuts
Gordon
(Sorry Sean - but you seriously can't dangle bait like that and expect not to get a bite)
Thanks guys.
I couldn't find that in the manual for the life of me. I can't adjust up and down independantly but that's not too important. At least I'll get some impression of the lag now.
Just got to find time to try it out!
ORIGINAL: siclick33
I know there's also a second doc explaining some of the Wc2 behavior, but the author of that was so in love with "conditions", that the book really only talks about conditions and doesn't really cover anything else.
http://www.futaba-rc.com/faq/faq-9z-q214.html
which shows you setting the delay twice - once for each direction. Dunno if that's of any help or not. You may be able to get more info by posting a "how do I do this" question in the radio forum, where there are some very experienced Futaba reps available to answer your questions.
Good luck,
Gordon
Thanks for looking for me.
Unfortunately the method described in the link relies on condition switching. This won't work to slow a proportional channel.
I know it's not perfect but I'm quite happy with the slow function in both directions. I think this is one area where the WC2 doesn't have the capability to do what I want.
