If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 120 of 145 FirstFirst ... 2070110118119120121122130 ... LastLast
Results 2,976 to 3,000 of 3625
  1. #2976
    flyinfool1's Avatar
    Join Date
    Jan 2002
    Cudahy, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Reaction 54 Jet Kit
    We will need pics when you do.....
    Jeff Borowski
    RAMS Club President
    www.ramsrcclub.com
  2. #2977
    Join Date
    Feb 2007
    Laurel, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, I am hoping that I didn't do wrong here even though it looks like things turned out ok.
    A friend of mine and I were doing one of my first kero starts (Wren 75) tonight in preparation for my first flight on Saturday. To make a long story short we had one heck of a wet start. Since I knew that this was because extra fuel had pooled into the turbine I decided the "run it out". The flames were contained in the tube and after about ten to 15 seconds went out. I ran the turbine for a couple of minutes and then proceeded with a shutdown. I had two follow-on starts that were uneventful and the turbine ran beautifully. Sounds fantastic!
    Would you have done the same? Standard procedure is probably to shutdown the turbine but at that point it was running and I was reasonably sure that the flames would blow out with the thrust that had built up. I think that the wet start ignition was "later" in the start process.
    Don S.
  3. #2978
    Join Date
    Nov 2004
    AucklandNorth Island, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi there,
    had a kit sent to NZ a couple of weeks ago and its under way. mate has Anthony s from Christchurch, flew it our Anzac meet, good fun jet, so now there will be 2 wood kit R 54s down under. will have Intairco retracts, kevlar tank glassed and painted,going use some of mods made on this forum, mainly the duct set up by Bobparks2. had to alter the retract mounts, fairly simple mod. changed the nose mount, had trim 10mm from the nose leg. will join the wing together tomorrow.
    Grant
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1776500   Click image for larger version.
ID:	1776501   Click image for larger version.
  4. #2979
    afterburner's Avatar
    Join Date
    Jun 2002
    New City, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Has anyone used a JC Rabbit(19lbs) on the Reaction?
    Marty
    Marty
  5. #2980
    ww2birds's Avatar
    Join Date
    Feb 2003
    Katonah, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not sure if it helps but I have a Wren 100 (about 22#) on mine .. I replaced a Wren SuperSport (18#) and the difference was quite noticeable .. flew fine with the SS, but LOTS more fun with the 100 .. the airframe takes the power easily and it's a pleasure to fly. I am sure it would be great with the Rabbit too. My plane is 20# dry.
    Dave
  6. #2981
    Join Date
    Jun 2002
    New City, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Dave. I've been flying mine for about five years now with a P-60 and although it's still fun, I think the extra thrust would boost the fun factor and make it feel like a new plane.
    Marty
    Marty
  7. #2982
    PaulD's Avatar
    Join Date
    Apr 2002
    Coquitlam, B.C., CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Go for it. The Reaction I had originally had a 14 lb'er on it and I put a Wren SS on it when I bought it. The original owner said it made the jet go from yawn to yeehaw.
    The extra thrust is a great addition even up to 22 lbs. If u are putting more jamb in, find a way to squeeze in more fuel so u can fun for more than 5 min.
    PaulD
    If it\'\'s too LOUD - You\'\'re too OLD
    Www.wircsrc.com
    MAAC Jet Committee
  8. #2983
    causeitflies's Avatar
    Join Date
    Jan 2003
    EASTERN OHIO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I flew mine for two years (six years ago) with a P-60. Brought it out of retirement last year with a Wren SS and it's a ball to fly on 18lbs. Would love to fly it on 22lbs but I fly it pretty hard so maybe I'll stick with the SS
    Mark P
    An Expert has made every mistake - A Master has made every mistake twice
  9. #2984
    Join Date
    Jun 2005
    San Jose, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I started out on mine with a Wren 54 mk 3, about 14 lbs thrust, then recently changed to a Jets-Mund VT-80, about 18 lbs, but also lighter than the Wren, and the fuel consumption is only a bit higher. Quite a nice improvement. I have a 75 oz JetTech (Gary Mueller) tank plus a 6 oz header, and set my TX timer for 6 minutes of flight time over 30% throttle.
    Bob
  10. #2985
    Join Date
    Nov 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi all,
    wings are joined, going for a trail fit to fuselage to day.everything has lined up well so far, nicely cut kit. have ordered a Jet Cat 100 RX to power it, simplified wiring harness and the specs show a kilo lighter than some of the other Cat Turbines being installed, should make it interesting. supply is about 6 weeks away, that should give me time to glass it and fit Bobparks2 duct design.
    Grant
ID:	1776909   Click image for larger version.
  11. #2986
    Join Date
    May 2003
    Vernon, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Legnum, I have built two R54's and I see something in your wing that troubles me. You have eliminated the triangular brace blocks at the plywood sandwich on rib W6 in favor of small traingular pieces of plywood. I suggest that this is a poor idea since the reinforcing blocks add a great deal of support for the gear mount. I have had my share of hard landings and runs off the paved runway. The first area to fail is that area. With the gear loads you will want as much support in that area as possible.
    John
  12. #2987
    Join Date
    Nov 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    john,
    that pic was taken before i had finished the mounts, all ply is aircraft grade 5 ply, base has the retract set in, with 2 more layers to fasten the retract to. hopefully this should be enough.
    Grant
ID:	1776950   Click image for larger version.
ID:	1776951   Click image for larger version.
ID:	1776952   Click image for larger version.
  13. #2988
    SPLIT S's Avatar
    Join Date
    Apr 2006
    Blandon, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Doing paint work on a friend's Reaction....
    Dan
    Hi Dad, Doing anything? Want to go to the field?
  14. #2989
    Join Date
    May 2003
    Vernon, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Legnum, I still see the potential to pull the retract mount plate and wing skin away from the W6 rib sandwich. There doesn't appear to be enough contact surface to hold that skin/gear mount plate to the rib. The load that the gear puts onto that system wants to pull the retract assembly to the rear and will take your current mount arrangement with it unless you put the triangular blocks in where the W6 rib meets the gear mount plate. The triangular blocks should be in the kit and are shown on the plans. I think the blocks are 3/4" triangular sticks the you will need to cut into segments to fit.
    John
  15. #2990
    Join Date
    Nov 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    have bolted wing to fuselage, need to sheet top of wing, will have another look at the retract mounts, have the 3/4 triangle strip, noted where it fits. then sanding, glassing, painting.
    Grant
ID:	1777330   Click image for larger version.
ID:	1777331   Click image for larger version.
ID:	1777332   Click image for larger version.
  16. #2991
    JohnVH's Avatar
    Join Date
    Dec 2001
    Ferndale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just put 4 more flights on mine this weekend, put crow into it, that is definately the hot ticket, takes some float out, also, put the brakes on while in the air so when it touches it sticks. Ill have HD vid soon of a flight hopefully from a buddy.
  17. #2992
    JohnVH's Avatar
    Join Date
    Dec 2001
    Ferndale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Video proof I still remember how to fly, this was shot this past saturday at a local field. Enjoy!
    Bobs old well used R54, JetcatP70, JR DSM2, Crow with brakes set in the air before touchdown, very light headwind, Thanks Ken for taking the vid!
    [youtube]http://www.youtube.com/watch?v=Df9MvEoPHu0&feature=g-all-u[/youtube]
  18. #2993
    BruceTharpe's Avatar
    Join Date
    Nov 2003
    Rogue River, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fantastic flight, John, I like your style! Looks like a tiny runway, and you only used half of it. I'd say you proved you're a GREAT jet pilot.
    BTW, excellent camera work, tell Ken I'd like to know his secrets
    BTE - Home of Quality-Minded Model Aircraft Kits.
    www.btemodels.com
  19. #2994
    JohnVH's Avatar
    Join Date
    Dec 2001
    Ferndale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks! I think that was my 7th flight on the R54 since I got it. Crow and brakes on is the hot ticket to super short landings on this tiny field. They are not all that good, but it works! Great job on a fun jet!
    I think the runway is 225' or less, field is 400'ish
  20. #2995
    PaulD's Avatar
    Join Date
    Apr 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice smooth flying John, hope we see you at Whidbey and/ or Princeton.
    PaulD
    Www.wircsrc.com
    MAAC Jet Committee
  21. #2996
    JohnVH's Avatar
    Join Date
    Dec 2001
    Ferndale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ill try, but doubtful Paul, all the jet events are planned on top of local stuff I have to attend, sadly.
  22. #2997
    bob1393's Avatar
    Join Date
    Jul 2003
    Port Orchard, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi John - thanks for posting the video. It's really nice to see one of my "old" planes fly!!! I was amazed at how fast you were able to stop after landing. I thought you would be using the grass runway for landings. Thanks again!!
    Bob
    AMA CD/Leader Member, JPO Dist XI VP
  23. #2998
    JohnVH's Avatar
    Join Date
    Dec 2001
    Ferndale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Normally I do use the grass Bob, but this one just felt good! If I didnt have the brakes set in the air I probably would have ran off the end of the runway. Having fun with the bird, most at my club have never seen one fly there, so they get a kick out of it, plus its sooooooo easy! Bruce designed a hell of a fun short field machine!
  24. #2999
    bob1393's Avatar
    Join Date
    Jul 2003
    Port Orchard, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Some people who get started into turbines want scale or something fast or sexy. The R54 is just a fun airplane to fly and more people should start out on one to learn all about turbine flying. FYI, Dean Wichmann had another R54 built (he sold his 1st one) by Paul D. so he could just have a fun plane and buddybox people on it.
    Bob
  25. #3000
    Join Date
    Jun 2005
    San Jose, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was flying at the club airshow over the weekend, and a photographer there some good photos of my R54.
    Photos by Kelly Collin, P51 Girl Photography
    Its pretty neat how the heat shimmer of the exhaust shows up in the first approach photo.
    Bob
ID:	1780195   Click image for larger version.
ID:	1780196   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
