P70 inverted?
My Feedback: (112)
CA
P70 inverted?
I would like to know if anyone has installed the jetcat p70 or any other turbine inverted, with the glow plug on the bottom? Jetcat states to keep it vertical +/- 75deg, I would like to have it close to 160 to 180 deg for ease of removal in my s/m saab.
RE: P70 inverted?
A friend here inverted his P-120 . It worked for a while and then it stopped to start. Seemed that the glowplug was not able to light up the gas. Then he had the clever idea to light up the gas with a bic lighter at the tailpipe. after almost loosing his eyebrows, he accepted this new procedure as a good idea, and he continued to fly... after about half a dozen times doing this, the turbine began to make metallic noises and broke... so, IMO don't think that's a good idea after all.
Enrique
Enrique
RE: P70 inverted?
I have a wren MW54 running in just about every thinkable angle....it has no regular mounts, so as i mount an d unmount it, the angle changes regularly. Sometimes the glowplug is up, sometimes down.....doesn't really matter, runs and starts just fine either way around.
Starting with a regular lighter never posed problems either, just get that hand out of the way quick
RE: P70 inverted?
I have run a SimJet 3000 and now a Merlin 160 with the glow plug at 6 o'clock. No problems at all.
I really don't think the propane gas cares what is up or down...
My Feedback: (8)
RE: P70 inverted?
We like to have you keep it out of the 6 oclock position for the following reason. If you happen have any raw fuel in the combustion chamber at light off you will get a truely flamey hot start. All the fuel will be sitting on the plug and once ignition occurs you have a real mess. Other than that it won't have any effect on hte operation, it is just one of those "what if" safety items.
My Feedback: (34)
ON, CANADA
RE: P70 inverted?
I know of many people who have the jetcat engines inverted (i.e. glow-plug facing down) and I have a P120 in a Gripen inverted and no problem starting. Todd has had over 200 flights on his Eurosport with the P120 inverted as well..not an issue
RE: P70 inverted?
ORIGINAL: John Redman
Reg. your theory about raw fuel and inverted mounted engine: Would not the raw fuel still be ignited a second later when the propane is ignited...?
I actually think it might even be safer to have it mounted inverted. One time I flooded my inverted mounted SimJet 3000, and it would not ignite because the glow plug was submerged in fuel... All I had to do was to hold the plane vertical and ran the starter a few times to drain the engine. Then it ignited safely on the first try.
