MW 54 MK III & Harpoon Combo...
#126
RE: MW 54 MK III & Harpoon Combo...
TS
I think you are in great danger of overcomplicating your Rookie. If you want to reduce the chance of FOD ingestion forget gear doors. They are a complication you don't need. Your main worry with the rookie is going to be making your first few landings. A heavy landing is likely to damage your gear doors which may curtail your flying session.
If you are worried about FOD make up internal wheel wells out of balsa / ply for the nose leg and use something like a cut down plastic container for the main wheels. If you have the RCJI which shows the Eurosport build you will see how to do the noseleg well.
Keep it simple!!
John
Keep it simple!!
John
#129
yep, i agree with you on that one john. I wouldn't put gear doors on my harpoon (mains anyway), unless i did them like i described earlier in post #70. and then it would be only on another new rookie or harpoon, without the airbrake cutout yet.. there should be no difference in those doors and having the airbrake down if you did land too hard, so there is no down side that i see to that type of geardoor/airbrake combo.. the only question is- would the plane be as stable with the airbrake deployed and 10 inches rearward? and about fod, a fod screen is a must, imo.
#130
ORIGINAL: daytona kid
..especially if u get a new kit without stock airbrake cut out yet...
#131
TS
The 'Roo / Rookies need the airbrake. I would stick with the dimension in the manual. If you make it much bigger it will slow the model down too much and may also lack rigidity and then you will have to stiffen it up which might mean you need a more powerfull servo and then------
Look let's not go down that road!!
John
John
#132
i agree again john, air-brake is a must. and original size is probably best.. but if someone made the airbrake/main gear door combo set-up, they would be best done in a some what triangular or p51 shape, to come closer to the origin airbrake area size, since the wheels would need more room than the original air-brake width.
#133
My Feedback: (10)
ORIGINAL: Treadstone21
Just went scooting back to post #70 ...keep it simple as you say is perhaps the best idea.....but looking at Sandor's 3 rd picture in post #71 his airbrake looks to be MUCH bigger than mine.. [:-] ( which is'nt cut out just yet by the way..)....? Have some folks enlarged their airbrake and for that matter... have some not bothered at all...?
the airbrake is original as mentioned in the manual
#134
mine had a recessed outline on the belly for the airbrake, from the mold i believe. i just cut it with a very thin dremel cutttig wheel. the mfg may have made some with different sizes..
#135
Yeah i was going to put two photo'up side by side this morning but i got sidelined somewhere along the way...there is clearly a difference between the two..
#136
My Feedback: (18)
CA
After owning 3 Rookies, I cut the speed brake larger on the last one. I was able to use more power when landing so the time it took to get to full throttle was cut in half. I was landing with a click or so of throttle, now I use around quarter throttle. I would recommend this and would do it again.
