Futaba 9C programing?
I'm trying to configure my flaps on one of the three position switches and was wondering how some of you were programing this in? I want the middle position to be at about 25 deg. and the full flap position to be at 45 deg.
The problem I'm having is that it seems the travel is almost 75% in the middle position. I haven't been able to figure out how to adjust the amount of travel when the switch is in the middle position.
Any help is appreciated.
Brandon
Brandon
My Feedback: (31)
KY
RE: Futaba 9C programing?
Post this on the Big Bird or sport board and you will probably get a quicker answer. Most guys here fly Jr. I fly FUTABA but i dont have my book. Russ
tcblr wrote ...
Mike
My Feedback: (24)
You can do this on the 9C in Pmix 7 which utilizes curves and makes this fairly simple to do.
Just go into Pmix 7, turn the mix on, make master Flap and then make slave Flap, you will then need to turn Link On, and make this active on Switch X (your choice) in the Center/Down position. On the next screen you will be at the curve screen so in the first and second curve position, I would leave mine at 0% and then in the third position, I made the percentage roughly 10%, in the fourth one I made my percentage roughly 20% and the last one I left blank.
This worked out well for me, you may of course need to change the percentages to suit your application, but I beleive this may be what you are looking for.
Todd
Todd
Thanks Todd,
Thats just the information I was looking for. I will give this a try... a couple of people told me to just use one of the sliders but I rather use a switch that way I can ensure I get the correct amount of deflection.
Brandon
Brandon
Hmm....I've GOT to try Todd's way!
I have used the following on several airplanes, but it does use up the P-Mixes...
P-1= Flap > Elev: 0/-10%; Link Off; Offset= -100 Switch B= Null
P-2= Offset > Flap; 0/+100; Linl= On Switch C= Down
P-3= Offset > Flap; 0/ +100; Link = On; Switch C= Down
P-4= Offset > Flap; 0/ +80; Link= On; Switch C = Center
Airbrake= Manual= Switch C. Flap = 50%
The % are adjusted to give you what you need
Now to try Todd's way.....
Greg
Greg
The simplest method is as follows:
1. Basic Menu - Aux Channel change to SW C. This provides 3 position +100% /0%/ -100%
2. Basic Menu – End Point With SW C in Up position adjust desired (say 75%), with SW C in Down position adjust as desired (Say 90%). This provides Flap Up with SW C Up, Takeoff Flap with SW C Centered and Landing Flap with SW C Down.
Play with the end points until you achieve the values you need. No P-Mixes required. (You can use the Basic Menu - Servo to immediately see the effects of your adjustments with the module removed during programming).
Dennis
Edit: If needed, you can also activate AIRBRAKE to provide delayed elevator trim at full flap.
Dennis
My Feedback: (24)
ORIGINAL: DP01
Dennis
Dennis
Todd
Todd:
Agreed. The method I describe allows you to start with SW C Up (Flaps Up), move to centre for Takeoff Flap, Move back Up for normal flight, Move to Centre for Takeoff Flap (Slowdown) and then to Down for Full Flap. (One has to transition from flaps Up through the intermediate position to Full Flap with a 3 - pos SW. It's just a matter of how long you leave it there!).
Dennis
Dennis
My Feedback: (24)
Hmmm...have to pull the old 9C out and check this but.... Setting end points on positions A and B are possible, IE: switch up, switch down..... on the 9C you cant set the endpoint for switch center unless I am missing something? That is why I was assuming your settings "+100% /0%/ -100%" meant takeoff flap/no flap/landing flap....? What you are describing is possible on my 9Z but I dont think you have this ability on the 9C without using a mix?
Todd
Todd
ORIGINAL: DP01
Dennis
Dennis
Thats how I currently have mine set up but as Todd mentioned unless we are missing something you can't adjust the center position's end point and thats the problem that I'm trying to address.
If there is a way to adjust the endpoint in the center position then no doubt this would be the easiest method.
Todd:
I have 3 aircraft programmed this way on my 9C, the method works perfectly and does not use a valuable multi point mix. You don't need to set the centre position, takeoff flap is set by varying the end point with the switch in the UP position and adjusting the linkage to set the zero flap position.
For example, 75% (with the flap at zero when the switch is UP) may result in 25º in the centre position. 80% may result in 15º. In the DOWN position, 90% may result in 45º whereas 100% may result in 60º.
These are speculative numbers only, the actuals are dependent on the flap horn and servo horn positions. Hence one has to play with the endpoint adjustments to acheive the desired movement(s). The method provides three definitive positions that are acheived by setting the UP ond DOWN endpoints. The CTR position is simply a function of the endpoint adjustment of the UP position.
Give it a whirl, you may like it!
Dennis
Dennis
My Feedback: (24)
Hmmmm.....
Still confused.... I fail to see how this allows you to set the center position flap throw. If you adjust point A to Flap up and point B to landing flap, switch center gives you a fixed amount of throw and therefore fixed amount of flap deflection that is not user defined....???.... In addition, by reducing the endpoint (ie: ATV) instead of setting you linkage geometry correctly for Full Up/Full Down deflection reduces the available torque and holding power of the servo?
Todd
Todd
Here's step by step:
Step 1: Assign Channel 6 to SW C.
Step 2. Change Endpoint of CH 6 to 20% when SW C is in the UP position
Step 3. Change Endpoint of CH 6 to 20% when SW C is in the DOWN position
Step 4. Place SW C in the CTR position.
Step 5. Adjust linkage so that the correct Takeoff setting is achieved. i.e. 20º
Step 6. Place SW C in the UP position
Step 7. Adjust endpoint so that the Flap is in the Full Up position (0º).
Step 8. Place SW C in the DOWN position.
Step 9. Adjust endpoint so that the correct Full Down setting is achieved. i.e. 50º
Step 10. Go Fly!
In effect, one uses the takeoff flap position as the centre point (in reality an ofset centre point) and adjusts the other ends to suit.
Dennis
Step 10. Go Fly!
Dennis
My Feedback: (24)
Ah....Ok, I see what you are doing! But, again...by reducing the endpoint (ie: ATV) instead of setting you linkage geometry correctly for Full Up/Full Down deflection reduces the available torque and holding power of the servos. Since P-mix 7 does not have many applications for our Jet needs, this is probably a better solution since it will not affect your linkage geometry nor will an adjustment to center switch position flap deflection change your flap up and full down deflections.
Todd
Todd
Todd:
Interesting point, however it's my understanding that torque and/or holding power is available at any position of the servo's rotation and is not a function of total travel. In any event, the mix method as described, also limits travel.
We must agree to disagree…
Dennis
Dennis
My Feedback: (50)
Todd trying your way but servo will not move. when I put switch in down position no matter what % I put in. Did I miss something. I followed you directions above. I'm sure its something obvious that I haven't done. I'm using channel 5 instead of 6 but in programing I used the channel 5.
My Feedback: (14)
MD
Unless I'm mistaken, switch C center is nuetral. To adjust the center position you would use subtrim and adjust the up and down positions with the endpoint. If your desired center flap position is not achievable with subtrim then you need to add a mix. For something like 0-20-45 you should be able to get that without the mix addded, for 0-15-60 you most likely would need a flap to flap mix.
