How to join drop tank halves
QC, CANADA
I bought this drop tank a while ago to use as a center line tank on my F-15. Needless to say, I was not happy with the quality as it came apart with just a gentle squeeze. You can see in the pic that it was joined with just resin and micro balloons. I have always been curious how this was done the proper way with fiberglass tape.
Chris
Chris
RE: How to join drop tank halves
In cases where I have an access hole, I spot-glue the tanks together with Pasti-Stic CA then run the tape around using a small wheel on the end of a small dowel.
In cases where no such access is possible, I tend to run the tape around one tank half, with it sticking out to form a lip ; then dress the lip to allow the second half to be a press fit ovetr that lip, slop some expoy with micro-ballons on it, and join the halves.
QC, CANADA
Sounds simple enough Gordon. A friend of mine came over last night and suggested that I just wrap the tape on the outside and finish over it. Probably more work in the end though. I've always wondered how good manufactures get the joint so perfect. Do they lightly pressurise it or something?
Chris
The few I have done had an over lapping joint molded into one side. Just put glue on the joint and slide them together, then putty the joint, sand and finish.
Steven
Steven
ORIGINAL: ChrisTrump
Chris
Chris
My Feedback: (13)
SC
Looks like a wet lay-up with a cab-o-sil joint. This works well when assembled properly. Both halves are wetted out in the tool, when cured they are joined in the mold with cab-o-sil and epoxy....How many do you need
One way to do it, which I have found works fantastic (looks like yours was done similar but with no care whatsoever) is to put a bead of thick epoxy/microballoon mixture around the inside lip of each and place them face down on wax paper (taped on a smooth level glass surface) to cure. Add some light weight to keep them down flat on the surface with out distorting them or the wax paper. This allows the epoxy to creep and form a widish gluing surface on both pieces. Once cured, remove from wax paper and use thick CA to glue them together. This works so well, that your only going to get one shot at getting them aligned to each other, so use slow CA to give yourself as much time as possible. It'll take a crash to separate 'em. This is the perfect method when you are unconcerned about the inside of a closed hollow object like this.
Paul
Paul
QC, CANADA
Thanks guys! These ideas are great. Who knew there were so many ways joining them, more than one way to skin a cat, I guess.
Chris
Chris
