200MPH JetCat P60 airframe?
RE: 200MPH JetCat P60 airframe?
Dave,
Just go to the RCU marketplace and look at: http://www.rcuniverse.com/market/item.cfm?itemId=85139
That bad boy will do 180+ with a P-60...and Obviously, you have no need to go over 200.........
Adios,
John
Adios,
John
Dave
I am sure the Jetco will do around 200mph with a 12lb turbine . It is smaller than the Bobcat and almost identical in configuration. David Gladwin had had his Bobcat timed at 199 mph!
John
John
True, but the Bobcat is a slouch compared with the StarJet. Much smaller and slimmer airframe with a thin but very clever wing. I think the StarJet would be pushing 200 with a Wren 44 and with a Supersport, well !!
Just off to fly my L39 if our field has dried out .
Regards,
David Gladwin.
Regards,
David Gladwin.
ORIGINAL: mr_matt
And the good thing about a Stingray is, when it is doing 200 mph, it LOOKS like it is only doing 300.......
Hey Matt, ever fly your Stingray on the P-70?
Kelly
Dave
If you prefer a scale model to a sport job the AMD Hawk should be good for around 180mph with a 12 lb turbine. It will have around 1:1 thrust/ weight. Have a look at the build thread run by SJN he is going to fly his soon.
I think he likes quick ones!
John
John
My Feedback: (10)
Hi Kelly,
Oh no, I saw one fly and shelved that idea fast. I have a P-60 for it, and have the P-70 earmarked for a Reaction 54.
The Stingray has been done (ready for paint) for months, have been busy with real job and my growing family.
Plus I forgot how to fly, that really makes me want to run out and finish that speeding bullet.
ORIGINAL: Kelly W
ORIGINAL: Gordito Volador
So how fast would that make the Bobcat with a P70?
My Feedback: (15)
ORIGINAL: Gordon Mc
[In the USA, it would still only reach a maximum of 200 mph; in the rest of the world the aircraft would go faster. The difference is due to the aircraft hitting the AMA Barrier - that's a phenomenon which is kinda like the sound barrier, but lower due to the air (or maybe the bureauc-rats) over here being more dense than elsewhere.
That's been proven to be fact based again since the rigged election!
Mark
Got to agree there Jeremy. I'm putting a Wren Supersport (18lbs thrust) into my Super Bandit and don't expect to get 200mph.
These models have more drag due to the ducted fuselage than the Bobcat or Stingray which are very clean aerodynamically.
I think a P60 in a 18 / 19lb Bandit would be marginal anyway.
John
John
FL
Remeber when the original bandit was designed around a 11 lb at best JPX??? I know things have changed in turbine design, but still the point it the same. I know the Super balsa bandit is great on a P-70. You don't need a 1:1 ratio for these planes to fly fast enough and perform well.
BTW the Bobcat composite is really fun on a P-60, my personal favorite combo.
Dustin
Dustin
