JetJoe OWNERS thread
Reply
Old 10-19-2010, 09:20 PM
  #3126
BJ64
BJ64's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JetJoe OWNERS thread
Quote:
ORIGINAL: Adrian Lewer
[sm=shades_smile.gif] Get ready for the bang...
I like a Man who's confident... [sm=bananahead.gif]
BJ
BJ64 is offline
Old 10-19-2010, 10:27 PM
  #3127
Adrian Lewer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have ordered my bits this morning, I got the 2 pice tail pipe, shaft tunnel, o ring set, set of ceramic bearings, and a new fuel pump (just in case). When it all arrives I will let you all know. (my first order from jet joe china )
Adrian Lewer is offline
Old 10-27-2010, 09:37 AM
  #3128
BJ64
BJ64's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your bits come in from China yet, Adrian?
BJ
BJ64 is offline
Old 10-27-2010, 08:14 PM
  #3129
DaveJohansen
DaveJohansen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quick question. In the picture I have 2 FOD screens. Mark sent me a FOD screen for my 1400, it's on the right . I had bought one from dream works, the left one. The larger on will not fit unless I cut the smaller ring, as it does not fit over starter motor.
The one Mark sent looks like it has to be installed inside the inlet underneath the starter motor inside of the 3 legs? Is that right?
Dave
ID:	1524207   Click image for larger version
DaveJohansen is offline
Old 10-27-2010, 08:32 PM
  #3130
fw190pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fod screen goes under the cowl. Remove the cowl place the fod on the inlet and reinstall the cowl on top of the fod screen. Just be sure not to pinch any lines or wires whenn reinstalling the cowl. If nothing else have to give Jetjoe credit for a very clever fod screen design.
fw190pilot is offline
Old 11-04-2010, 06:40 AM
  #3131
BJ64
BJ64's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anthing arrived yet mate?
BJ
BJ64 is offline
Old 11-04-2010, 07:17 AM
  #3132
hapyjac2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: DaveJohansen
Dave
Dave,
just remove the blue cover and insert. The smaller FOD screen works great and is easy to install.
hapyjac2 is offline
Old 11-20-2010, 02:41 PM
  #3133
f6hlct
f6hlct's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just bench ran my new/used JJ1400 for the first time and it displays a bit of an odd start up. Once it gets to idle, everything else is ok though. I was told in the past with my JJ1200, that I should shut off my propane at 30K, but it will not start this way as it just sinks in RPM. Even if I let the propane stay connected up to 45K which is the set idle speed, it will sink to 37K on removal and take about 15 seconds to get back up to 45K again. As mentioned, it seems to run fine once stable at 45K. It sounds like there may not be enough Kero on the ramp up, but I am not sure what parameter to look at. Any suggestions?
f6hlct is offline
Old 11-20-2010, 09:08 PM
  #3134
fw190pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Set parameter27 to 27 or 28 and raise parameters 28,29, and 30 by 1 and try that. This should help but make sure it doesn't get too hot during fuel ramp.
Old 11-21-2010, 04:36 AM
  #3135
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would also up the stability delay to about 50, decel delay to 20+ and reduce the egt max to 800
Xairflyer is offline
Old 12-16-2010, 12:12 PM
  #3136
Mavericksa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all jet joe owners,
I bought a second jj 1400 a while ago without any manual. I need an assembly and/or owners manual to replace parts etc. Is there any one that could help me with this???
Please mail me a copy to dreamwings@mweb.co.za
Will appreciate any help
Cheers
Mavericksa is offline
Old 12-16-2010, 12:16 PM
  #3137
DaveJohansen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sent you a copy
Dave
Old 12-17-2010, 03:05 AM
  #3138
Mavericksa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sent you a copy
Dave
Dave,
Thank you so much for the owners manual and all your help!!! Appreciated.
Any one that still have an assembly manual for the JJ1400 specifically............please help.
Thanks !
Mavericksa
Old 12-17-2010, 03:27 AM
  #3139
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Mavericksa
Thanks !
Mavericksa
I done a stripdown/rebuild thread sometime back on here, [link=http://www.rcuniverse.com/forum/fb.asp?m=9458885]JJ1400 stripdown/rebuild[/link] you should get all you need from that.
Would be interesting to see Jetjoes instructions for the JJ1200 kit if anyone has them.
Old 12-17-2010, 04:55 AM
  #3140
john4648
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have a JJ1400 that am getting ready to list. Complete full autostart. Has new combustion chamber, NGV etc. Serial #606. Thinking in the $900 range.
email me at j@neb.rr.com if interested.
john4648 is offline
Old 12-24-2010, 12:54 AM
  #3141
Mavericksa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hallo all Jet Joe experts
Firstly, I wanna thank Xairflyer and Dave for their help with my assembly manual request. Xairflyer..........great thread and job done!!!!!!!
I also experienced the next problem and hope you guys can help me.
I have a JJ1400 #716. Since I bought it and installed it on a test bench, I have started it about 7 times ....... it run great!!!! I basically emptied a 1,5 liter tank with each run. The EGT never went higher than 400C. With the last start I heard that my starter engage and then released............engaged and release with the ramp up. I decided to dismantle the starter (still the starter that was on the JJ1200's) from the turbine and to check and clean the o-ring. I saw that the o-ring was worn out a bit and also cleaned the "bendix". The replacement o-ring I installed is a teeny little bit oversized (OD). When I started after o-ring replacement it seems that the starter/bendix did not release. My temps went up to 780C - and turbine shut off. Could it be that the starter/bendix did not release and more fuel was pumped by the pump to reach rump up revs and resulted in hot start??? I mean.......before o-ring replacement my turbine was working 100%.......[&:]
Please.......any ideas??
Mavericksa
Old 12-24-2010, 08:22 PM
  #3142
fw190pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the starter doesn't release it will cause the turbine to overheat. You will also be lucky if it didn't destroy the starter motor. Easy fix for a worn starter oring is to simply flip it over. It will work at last almost as long as a new oring.
Old 12-25-2010, 10:07 AM
  #3143
GSR
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If your temps never went over 400C your engine is not running. Adjust or replace your thermocouple.
GSR is offline
Old 01-04-2011, 04:34 AM
  #3144
hapyjac2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Gents.
I have a jet Joe 1400 thats been in a box for a while. I'm not going to use it. I know it probably needs bearings and some TLC Comes with start up equip. 2 valves, ECU, (Regal), wire harness, engine mount, etc. no battery.
It may need a new starter motor since the leads are not attached to the starter motor. Even have the GSU and manual. I'm looking to get $500.00 for the whole box of stuff. shipped free in US, out side we can work a deal. If your interested write me a note for photos. Great for parts or could be fixed. It did run fine, before the bearings started geting noisy.
hapyjac2@aol.com
ID:	1542140   Click image for larger version
ID:	1542141   Click image for larger version
hapyjac2 is offline
Old 01-21-2011, 10:22 AM
  #3145
streakflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Everyone
                          Hope I'm in the correct thread as i have purchased a second hand JLT Turbine which i believe is a rebadged JETJOE
                          I'am new to RC turbines and purchased this one just to bench run, I have read this forum thread and am now aware of the                                                 problems that have been encountered, This hasn't disheartened me as I do like to tinker.
                          I believe my engine to be basically ok at the moment although I cant feel the preload so that will need looking at.
re">   My main problem is the GB Hobbies ECU will not ramp the fuel pump on start up, it will run the pump to Prime ok
re">   I'm not sure if my radio set ( SANWA VANGUARD) will work with the ecu, although i know the radio gear works
                          I have set the radio to ecu as per instructions,
                          my manual start method is to spin on starter, apply glo power, open gas, it will then light up as expected then further motoring on the                               starter the engine will accelerate up to 25k rpm and 250c egt on gas, but no power to the fuel pump (0.0v) to ramp.
re">   Does this sound like an ecu fault
                          please help and many thanks  Adam
streakflyer is offline
Old 01-21-2011, 10:52 AM
  #3146
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, the minute the ecu see's 100c it should start running, check the ecu to make sure there are no burnt tracks on the pcb, I have fixed a few with this problem.
Old 01-21-2011, 02:14 PM
  #3147
i3dm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also check your GB ECU paramaters "start allowed RPM" and "start allowed EGT" to make sure theyre dialed in right.
i3dm is online now
Old 01-22-2011, 12:55 PM
  #3148
streakflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Xairflyer and i3dm
many thanks for your reply's
the ecu parameters are start allowed rpm =7 (7000rpm i guess) and start allowed egt =100 the engine has been to 25000rpm and 250c egt on gas and starter according to the display unit and it wont start the pump
so i opened up the ecu and found a burnt track (bottom right in pic) however there is good continuity across the track so I'm not sure if thats the problem, any thoughts ?
also should i strip the engine down to sort out the preload before attempting another start ?, Xairflyer I have read your thread regarding your rebuild of your jj1400, were there any ill affects of leaving out the rear o'ring? I'm assuming the rear bearing must be a good interference fit to stop the outer race rotating to leave the o'ring out ?
Regards Adam
Old 01-22-2011, 12:57 PM
  #3149
streakflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oops the burnt track is bottom left in the pic as it uploaded
Adam
Old 01-24-2011, 04:12 AM
  #3150
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Obviously if there is a burnt track, there is a problem with the ECU, chances are the component (more likely a mosfet) burnt out just before the track did, can you take a pic of the other side of the board.
Also can you make the pump run by connecting a battery, 1.5v is enough, disconnected from the ecu of course.
Removing O ring is not a problem, last tunnel I got for my wren did'nt even have the groove anymore, so it is obviously a better job.
Reply
Display Modes
