JetJoe OWNERS thread
#851
RE: JetJoe OWNERS thread
Better you contact to: (from JJ web page)
JetJoe agents, distributor and services worldwide:
Turkey:
Mr. Murat Bukey and Cumhur Guvenc
Sehitler Cad 18/3 Alsancak Izmir 35230, Turkey
Tel: +90 532 615 07 33
Web: www.gjet.net
Email: [email protected]
Turkey:
Web: www.gjet.net
#852
Sounds like you need a new starter motor, or do as the electric car dudes do and cut the commutator and replace the brushes if you can.
There is no PWM to the starter motor, only a FET that switches the motor on or off.
But as Joe says contact the agent you got it from...
#853
ORIGINAL: bukeym
Hi Guys,
I just purchased a new set of JJ1400. However we are not able to start it.
When we initiate the start the ECU (version 3.0) is unable to spin the rotor or sometimes it spins but at very low speed. Therefore the turbine is unable to ingnite. If it ignites for some reason the turbine cannot start and dispays time-out. During some starts the turbine goes into fire (big propane fire) and then tries to start the turbine and then displays “weak gasâ€.
I believe this is software problem becuase the intial voltage to the start motor is too low. Can we change the hidden parameters so that the propane start voltage to the electric starter can be increased?.. Or is there any other suggestion?..
Best Wishes from Turkey (the first JJ owner in Turkey)
Murat Bukey
Hi Guys,
Murat Bukey
Hi a quick call to your local rep will assist, as if you see a low voltage on screen it means your battery is toast[:@][][>:] with maybe a dead cell. If the initial reading is 8.4 volt there should be minimal drop on the starter motor engaging, so substitute and try a new battery pack.....
Paul
#854
NJ
The start motor leads may be shorted to the housing. If the leads were poorly soulder to the motor they can short to the housing. This condition can and will cause a slow or no start motor. I had the same condition with my 1400 and cooked the ecu on the third or fourth try to start.
#857
ORIGINAL: PREACHHAMES
Here is my completed Tamjets F-16 powered by my JJ1400.
Taxi tests this weekend; maiden flight one evening next week!
Greg Hames
Greg Hames
Greg
Best wishes that all goes well on the test flight. Nice model! another for my long 'to buy list'.
Paul
#858
Bench running a necessary evil??? Never bench ran my JetCat P60 or my Wren 44 Gold before installing. Both run as advertised without issues for many hours. This bench running condition must be specific to JetJoes??
Dave
There is a vast difference between a Wren 44 and Jetjoe shipped turbine, as Mike at Wren will have test run theirs, only after a professional build, making sure that the FADEC parameters are all set up and all is functioning well. QA/QC is not high on the list for Jetjoe as this thread confirms. They continue to ship with basic defects and some reps carry out a 'pre service' as who needs the grief of a sticking bendix of folded lube tube on a brand new turbine.
So for Jetjoe owners bench running is a necessary evil and some Jetjoe turbines just never ever make it into the air as Chris on this thread will confirm. Just another disappointed Jetjoe customer 4000 miles away from China who got about 90 minutes bench running before melt down.
Paul
#859
I have a 1200 kit and a simple fix for kinked lines is to mark and drill three hole in front cover and let fuel and gas lines come straight out the front, sure does make the front cover a lot easier to put on too. Maybe doesn't look real pretty but better than a kinked lube or fuel line.
#860
My Feedback: (58)
Perfomed my taxi & brake tests this past Sunday evening.
All went very well and the jet tracks, rolls out, and stops in a perfect straight line.
Waiting on a nice calm evening for my maiden flight at my local regional airport.
Engine now has 2 hrs. 4 min. total time.
I hope to have video of the flight.
Greg Hames
Greg Hames
#861
The problem with the JJ1400 is solved. There was no problem with the starter motor, no short circuit et.. The problem was with the hidden parameter in the FADEC. Parameter 15 (Propane Start Voltage) was too low..
Thanks a lot for all comments.
#862
ORIGINAL: bukeym
Thats my main point Wren and Sara never ship out till its working right. Spot On
Paul
#865
My Feedback: (26)
FL
ORIGINAL: rcdriver22
hi
Paul
ORIGINAL: bukeym
Paul
Isnt that what is being done at the U.S. distributer? I believe Gabe Brown wont let one go until its running like a top.
#866
Dear B1Driver,
Who is Gabe Brown? Is he the North American distributor/support for JetJoe? Do you know his contact information?
I have a JetJoe engine. It started lif as a JJ1200, then upgraded to a JJ1400, then rebuilt a few months ago with the latest improvements. It is in a Super Reaper. I hope to fly it in the next few weeks. The snow just left here and I need to warm my thumbs up on a sport plane before I fly a jet.
DW_Crash
DW_Crash
#867
My Feedback: (58)
B1Driver,
Gabe Brown (JetJoe U.S. Distributor) setup my JJ1400, ECU parameters, and test ran it prior to shipping. He offers this service to all his customers if they wish.
It has 124 minutes total run time and is still on its first McCoy MC-9.
Winds here in N.C. have been 10-20 mph all week. Hopefully, they will settle by weeks end for my maiden flight.
Greg Hames
Greg Hames
#868
My Feedback: (26)
FL
ORIGINAL: dw_crash
Dear B1Driver,
DW_Crash
Dear B1Driver,
DW_Crash
Luis
#870
ORIGINAL: hendrix
Hi Paul.
You reminded me my experience with JJ1400 and now that my new turbine works great, all seem like a bad dream
I am getting ready to buy the plane as my pig money box is almost full he he he.
Chris
Hi Paul.
Chris
Glad your new turbine is working well, the german engineering is excellent (and cheap) What's it going to fly in??
Paul
#871
ORIGINAL: dw_crash
Dear B1Driver,
DW_Crash
Dear B1Driver,
DW_Crash
Paul
#872
ORIGINAL: B1Driver
hi
Paul
ORIGINAL: bukeym
Paul
Paul
#873
Hi Paul.
It will either be the boomerang intro with fixed gear for the start or the STORM from adjets or the velox from digitech turbines or the Harpoon II from digitech again .
I have not made up my mind yet but max price will be ~1000 Euro.
here are some photos:
#874
ORIGINAL: hendrix
Hi Paul.
It will either be the boomerang intro with fixed gear for the start or the STORM from adjets or the velox from digitech turbines.
I have not made up my mind yet but max price will be 1000 Euro.
Hi Paul.
It looks great, cool dude. Dropped yiou a PM tonight.
Paul
