Kingcat smoke tank?
My Feedback: (72)
WI
RE: Kingcat smoke tank?
I got a 93oz tank from Gary Muller have some pic posted at this link.the tank fit great and the smoke last a long time.I hope I can get some more pic this weekend at are fun fly. Paul
http://www.rcuniverse.com/forum/m_29...tm.htm#3017652
FL
I used a 40 oz DuBro over the rear spar, it sits in there an an angle. then a 20oz Dubro between the main tanks over the 16 oz BVM supplied hopper tank. This gives 60 oz of smoke. The advantage to this is, it keeps most of the Smoke fluid much closer to the CG. Plus it may even be cheaper....
Next I will try putting a UAT before the pump to eliminate the annoying bubbles on long down hill manuevers toward the end of the flight.
Good luck!
Good luck!
