Info on Sophia j450
Paper weight
Looks like you haven't been reading the other threads discusssing the Sophia engines. They are manufactuer discontinued, there are no parts or service for them. While you might be able to cobble together some used and/or aftermarket parts designed for other engine, the going is going to be tough.
If you need a paperweight, then go for it.
Info on Sophia j450
Don't consider buying a sophia unless its very very very cheep and be prepared to throw it in the scrap part box WHEN it blows up cos it will.Plus I belive the 450 runs mainly on colemans fuel which is a lot dearer than A1.plus the oil pumps pack up, plus...
Sorry Mr hoya of the sophia corp, who I have had many unfortunate and expensive dealings with.
